Bobbin spins instead of needle going
Check power gear selection (see bobbin spindle).
If you need a copy of manual;
https://vikatikki.net/wp-content/uploads/2017/01/husqvarna-viking-6570-manual-en-web.pdf
SOURCE: I have an older Husqvarna sewing machine (sle 6570
In the middle of the bobbin winding spindle, there is a piece we'll call a "flange". It is spring loaded but sometimes sticks. When it is in the center of the spindle it diengages the sewing machine drive system that drives the needle. Make sure it is not in the center of the flange. You can use a small screwdriver and gently press the flange outward and hopefully you may hear a small click and everything will be fine. Make sure also that the round plastic piece the flange is located in the center of, is pushed all the way to the left, (in you're sitting in front of the machine) if you pull that round platstic "knob" to the right, like you're trying to remove it from the flange, it will pop outward and engage the tranmission for sewing heavy fabrics.
SOURCE: my viking 6570 sewing machine needle will not pick
Remove the bobbin case and lean the machine back. Bring the needle down as low as it will go using the hand wheel. Locate the tip of the needle in the bobbin area. Rotate the hand wheel forward and as the needle rises, you should see the tip of the hook cross the back side of the needle, moving left to right. If it is crossing below the eye of the needle, find a qualified repairman. If it crosses above the eye, try a new needle and make sure that the flat side is installed toward the back.
SOURCE: straight stitching needle plate for a viking 6570 sewing machine
have you tried sewingpartsonline.com
