The manufacture of that set says
Region code setting
All DVD discs are coded by the sales territory. Please note the built-in DVD player is set to Region 4 coding by the factory, which cannot be changed. This is in compliance with DVD patent requirements.
good luck
https://www.6ya.com/mr.mike
Tvs are sold by aldi as its out of uk its set to region 4 and cannot be set to others. same with the dvd players if it has one built in. you would be able to sort this if it was an other model like samsung with a firmware update but this brand does not have a firmware update. you would need to replace the review board to an one for your area,
SOURCE: Unlocking the region code (code2) on a Panasonic DMR E85H to use region 4 DVD's.
hmmm..ok..do you have user manual, or do you need one?
SOURCE: LG RH2T160 unlock all regions
press HOME
scroll to SETUP OPTIONS
scroll - down - to the LOCK icon
press SEVEN ZERO's - message appears
press ENTER.
also used after message; 'unknown disc; please check disc again'..
my indonesia built area 4 marked lg rh2t160 would
play most area 1 dvds, but not all, from new..
7 X 0 hack using remote = plays all discs..
SOURCE: unlocking DVD rom to multi-region TS-L632D
You can change the DVD region four times only, the fourth change will lock on that region permanently.
There may be a firmware upgrade that make your DVD region free, but if you make a mistake or install the wrong firmware upgrade then the DVD will be a piece of junk. You will need to Google search for DVD firmware upgrades for your model DVD.
The best way to view DVDs from other regions is to install a piece of software that defeats the region code. I use a program called DVD-RegionFree from
www.dvdidle.com
There are possibly other programs available, again Google search for them.
SOURCE: Pioneer AVH-P4100 dvd region unlock
Hi Scotty,
I have some bad news for you, this player is preset to region 1 and it cannot be changed, here is an extract from page 7 of the user manual...If you need the manuals email me at [email protected]
DVD video disc region numbers
DVD video discs that have incompatible region
numbers cannot be played on this player. The
region number of the player can be found on
the bottom of this unit and this manual (refer
to Specifications on page 113).
Testimonial: "Ok well that is bad news. If i cannot change the region setting on the dvd player, can I change the egion setting of the DVDs?"
