SOURCE: Jet spray nozzle not spraying water.
If no water is coming out at all, it might be that the inlet filter is clogged or the Est. time shows the code IE. To clean out the inlet filters, unplug the washer, turn off the water, open the valves, take a filter cap thing and try rinsing it out. To put it back to operational use, reverse the steps above.
SOURCE: No steam - steam jet does not heat
1. Turn off and unplug the machine.
2. Wait 2 hours.
3. Remove the water tank.
4. Remove the top cover. (Two screws in the top)
5. Remove the back/side cover. (Two screws along the top crimp)
6. Locate the thermocouple.
6.a The thermocouple is on the left side of the machine, on the back side of the heater block. It's a small pin with a plastic knob on it.
7. Press the pin on the thermocouple in.
7.a. If the thermocouple is not out, pull it out and press it back in.
SOURCE: my spa leaks
Good luck, I'm in the process of chipping away at the foam 3 days so far, still have not found leak, Tried everything dyed water, but with the way they do the STUPID foam the water could be dripping 3ft away from leak... **** poor design and the can foam to fill it back up is gonna cost a small fortune,,
SOURCE: i have a leaking jet in a pearl jet tub. it's an
one of the quick ways to fix leaks at jets is by using Millaput two putty resins mixed and worked round the outside of the defective jet hope this helps
SOURCE: dont know how to change the battery in Thomas Jet engine.
Hey. I was looking for the same thing and found this answer on yahoo answers:
"loosen the phillips-head screw on the underside front center of the jet engine train (you might not have noticed it - it is behind the coupling magnet assembly, which you can move to the side and also has an opening to access the screw) - once the screw is loosened, you can lift up the 'jet engine' from the base to access the battery enclosure"
http://answers.yahoo.com/question/index?qid=20071225073953AAHYJKb
