NO SOUND, ONE CHANNEL ONLY - Xfinity Help and Support Forums - 818726
https://forums.xfinity.com/t5/Non-X1-Service/NO-SOUND...CHANNEL.../818726
Oct 23, 2010 - All the other channels on this TV have sound, and the other TV in ... Between thevolume and channel buttons tere is a help on the top, and a mute and fav on ... I have a Comcast Universal Remote with the red ok button. ... The one upstairs has working sound on all channels,the one downstairs does not.
No sound on TV - Xfinity Help and Support Forums - 2890431
Apr 7, 2017
Solved: No sound on some channels - Xfinity Help and Support ...
Jul 13, 2012
Solved: No sound on certain channels - Xfinity Help and Support ...
Dec 15, 2011
Solved: No Sound on a few channels with TV fed by Digital ...
Oct 5, 2009
More results from forums.xfinity.com
Press it hard and try to vibrate the button sometimes it makes bad contact or random connection. Also try different remote or ask you cable provide for replacement.
SOURCE: my SCREEN HAS "MONO"
http://www.retrevo.com/s/RCA-27F520T-TVs-review-manual/id/402ci358/t/1-2/
try here for the manual
SOURCE: Olevia 537 - wont select HD channels
I assume the control panel on the tv still works correctly?
If so i would think you have a remote problem.
If thats the case let me know I will send you a link to instructions to repair your remote.
lone99star
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/jason_77a19afa8d604dee
SOURCE: My Olevia TV will not change channels using the remote or buttons
First thing, check batteries in remote, next make sure there are no obstructions between your remote and your tv. i would then call olevia tech support and describe your problem. sounds like the remote sensor has failed. usually covered under warranty. check with olevia to see if they have a factory wide problem or issue with remotes. persistance pays off in this case so just keep on top of tech support. hope this helps, john.
SOURCE: Pro-96 ,channels 1 thru 9 are locked out ,only 0 is
You are referring to banks, not channels. When bank 0 is active, then you push 0 to de-activate it, you have now removed all your banks from the scan list. To re-activate any bank, just press any number. This is confusing because locking out a channel and removing a bank from the scan list are two very different operations but use the same terminology.
For more information and some tutorials to help with various functions, visit this site: http://support.radioshack.com/support_tutorials/communications/20-526.htm
SOURCE: No sound on my Sanyo LCD 32" flat screen tv
I had this same problem this morning. Luckily, when I reset the whole thing and did the channel search again the sound returned. I have no idea why it fixed it but it did. Hope this helps you.
