Sharp 30" Built-in Trim Kit for R530BS and R530ES RK51S30 Logo
S
Suzy Wahl Posted on Feb 02, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Why does my R530BS microwaved keep blowing its fuse?
Every time we replace the fuse inside, it blows as soon as we press "start"
Stan Naramore
Level 3:
Guru:
  • Sharp Master 531 Answers
  • Posted on Feb 02, 2019
Stan Naramore
Sharp Master
Level 3:
Guru:
Answers
531
Questions
Helped
208966
Points
2468
There is an electrical short. I recommend you do not try to Start it again, it can cause a fire.
If it is out of Warranty, buy a new microwave
If it is still in Warranty immediately have it repaired
by a qualified company serviceperson
William Miller
Level 3:
  • Sharp Master 9,179 Answers
  • Posted on Feb 04, 2019
William Miller
Sharp Master
Level 3:
Answers
9179
Questions
Helped
4481413
Points
21747
Shorted high voltage capacitor.
See http://www.microwavecontrol.com
Chaz Karchner
Level 1:
Habit-Forming:
New Friend:
  • Contributor 30 Answers
Chaz Karchner
Contributor
Level 1:
Habit-Forming:
New Friend:
Answers
30
Questions
Helped
16711
Points
88
You have a dead short. Check the transformer wiring for burnt between the capacitor,its resistor leading to magnatrometer. If that is ok you may have a lose wire leading to a bad start switch or door interlock.
I like the Panasonic Inverter Geius Prestige series for an all around replacement. Should you are looking for an upgrade.
5 Related Answers
Anonymous
  • 840 Answers
  • Posted on Mar 08, 2009
SOURCE: No parking lights, fuse keeps blowing.
There is a ground not connected or a wire open that is causing it to blow
kirtec auto
  • 1348 Answers
  • Posted on Jul 18, 2009
SOURCE: taillights and license plate lights not working
there is a short somewhere.put a test light in place of the fuse.
the light will glow bright.when the short is removed,the light will go dim
Anonymous
  • 165 Answers
  • Posted on Jul 20, 2009
SOURCE: #14 fuse on 1999 jetta keeps blowing. replace and it starts again
there is a short somewhere in the wiring
Anonymous
  • 16 Answers
  • Posted on Nov 10, 2009
SOURCE: EFI fuse Keeps Blowing
I had the same problem at one point. My issue was a bad grounding point from the battery to the chassis. I would say check all of your grounding points.
Kiri105
  • 286 Answers
  • Posted on Aug 26, 2012
SOURCE: tail light fuse keeps blowing
Seen this before ,,, You have to disconnect the ground wire from the radio to the vehicle... What has most likely happened is that the radio earth has been connected to the previous radio's illumination wire.
What will appear to be a ground connection while the side lights are OFF is in fact a positive that acts a a ground connection untill the side lights are turned ON
The radio should be earthed properly there after..
Whirlpool microwave fuse has blown multiple times
It depends on which fuse and when it blows. Wish you had mentioned that.
But usually it's a defective door switch or door switch mount.
If the fuse blows at random times while it's cooking, it may just be a loose fuse holder. Those have to be replaced due to metal fatigue, not just squeezed tight with pliers.
If it blows as soon as you hit "Start" to begin cooking, you have a shorting high voltage capacitor.
If it blows when you open or close the door, you have a loose or defective door switch or latch.
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
Microwave keeps blowing fuse
There are three possibilities, a bad magnetron, high voltage capacitor, and diode. In rare cases the high voltage transformer will be an issue but unlikely, if the microwave oven is more than 5 years old consideration should be given in replacement.
THE MICROWAVE KEEPS BLOWING FUSES, AS SOON AS I HIT THE START BUTTON THE FUSE BLOWS.iT WILL KEEP THE TIME AND THE LIGHT WILL COME ON BUT AS SOON AS i HIT START IT BLOWS
Sorry to read about your problem, I hope this helps you out.
you have a defective control board
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
1helpful
Please help me
Q - My microwave went dead when I opened the door ( same problem as closed the door ).
A - This often is a stuck or faulty door switch and it has blown the interior microwave fuse.
Q - My microwave is completely dead.
A - House fuse has blown or interior fuse inside the microwave has blown ( usually a part inside the microwave makes this fuse blow ) Sometimes a bad fuse holder inside the microwave cannot hold the fuse tight enough and the fuse will blow as well.
Q - My microwave blows the fuse inside itself as soon as I push the start button.
A - Usually a shorted high voltage capacitor...see components section.
Q - I burnt something in my microwave and now it is dead...help!
A - The fuse inside the microwave may have blown, but more commonly the flame/oven thermostat has sensed the over cooked food and the flame/oven/cavity thermostat has opened up - Info on that
Q - My microwave seems to shut off every once in a while, what might be wrong?
A - Make sure you hear the fan is still operating in your microwave. Next is to make sure the air intake grill on your microwave is not plugged up with air borne dust and dirt.
Q - The microwave makes a loud "hum or buzz" noise but will not heat up the food?
A - 9 times out of 10 this is usually this is a bad magnetron, the other time is sometimes a bad high voltage diode. See components section.
Sharp R-9H66C Microwave Convection blowing fuses
check high voltage transformer and high voltage diodes, condencer, and magnetron.,
3helpful
4answers
Fuses keep blowing out
In case it's still helpful, I'll inject a little sanity into the replies.
If the fuse blows as soon as you hit Start, it's probably a shorted high-voltage capacitor. That's usually economical to repair.
If the fuse blows a few seconds after you hit Start, it's probably a shorting high-voltage transformer. That's usually not economical to repair.
It's not radiation (non-ionizing RF by the way) that's the hazard, it's the voltages.
Blown fuse
Be doubly sure your microwave is unplugged first, of course! Be sure the fuse is not loose in the holder. If you can rotate it in the holder easily with just a thumb and finger, then it's too loose and the holder should also be replaced. That looseness causes a heat buildup, which makes the fuse melt open inside over time. If the new fuse blows as soon as you hit START then you likely have a shorted high-voltage capacitor. If it blows again a few seconds or minutes after you hit START, then you likely have a bad high-voltage transformer or magnetron. It's not inherently unsafe to replace a fuse, as long as you heed the safety rules. The microwave does contain and prodcue voltages that can be instantly lethal. Feel free to see my safety info via my listing here on FixYa: http://tinyurl.com/yzjozk
2answers
Fuse keep blowing up
You have a short in the system. removeing the fuse was not a good thing to do. The fuse in a microwave helps keep the system from an overload which can and I have seen this blow-up. The micro pump inside might have a dead short it,
5answers
Microwave not works
WARNING: Microwave ovens are the most dangerous consumer appliance to service due to up to 5,000 V at high current inside. Even with the power off, there is a HV capacitor that can produce a lethal kick. This capacitor must be discharged before touching anything in the microwave generator circuitry. DON'T remove the cover yourself unless you fully undertand the SAFETY issues involved in working inside a microwave oven. A microwave oven is possibly THE MOST DANGEROUS common consumer product to service. About the only "easy" fix would be a blown fuse, if it keeps blowing, don't go any further unless you know what you are doing. Your likely options are a blown high voltage cap, diode, or the magnetron. Good luck(but luck has nothing to do with it ;] )
Top Sharp Microwave Ovens Experts
ZJ Limited
ZJ Limited
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
