Question about Nixon Watches
Can someone please help me set the time on my unit ss steel band Nixon watch?. I have had it 3 years and never been able to set time on it.
6ya staff
SOURCE:
Anonymous
SOURCE: Nixon Watch band
I tried the hammer plyer thing way back but took a bunch of time and stress, then I took it into a skate shop where they sold nixon watches and they had an actual tool supplied by nixon and all the **** needed to do the job.
Posted on Nov 27, 2008
escapement
Arturs Kalnins
  • 2338 Answers
SOURCE: stainless steel band adjustment
You may or may not have arrows inside bracelet. Arrows are pointing the way the pins must come out.
First you have to find out what sort of pins or even screws are used to keep links together.
Examine both bracelet sides and find the side where pin ends have a groove.
Start with a tiny screwdriver and unscrew one of the screws. If it turns, but doesn't come out, that means you have a pins instead.
For removing pins the best would be pin removing tool (approx.5GBP on ebay), but it's possible to do the job without it.
Take a hardened steel needle and blunt the sharp end to the approx. size of pin end diameter using any sharpening stone or sandpaper. Get an old towel and fold it to make a soft base for work (like small cusion). As you don't have a special bracelet holder you will need a pair of helping hands to hold the bracelet steady upright. You will need small hammer and pair of flat nose pliers as well.
NOTE: The pins MUST be driven split end out first, not vice versa. Make sure that the grooved pin ends are facing towel, not the needle and hammer!!!
Now place the watch on the folded towel, take that needle and smallest hammer you have and start driving the pin out using light blows. Do Not hit hard, as you will brake the needle, scratch your watch or even injure yourself. Watchmakers are using 45 gram hammer, so, calculate your strength of blows.
After a few blows check if the split end is coming out and when you see that the end is long enough to grab it with pliers, pull the pin out with pliers. When pulling, do NOT turn pliers, as pins tend to brake when twisted. Use firm grip and your strength to pull the pin without twisting.
After shortening the bracelet or adding extra link(s) make sure that the pins go back EXACTLY the same way as they came out- the blunt end first in the hole and the split (grooved) end last. Before doing that check remaining pins in bracelet to make sure that you put them back from the right side of bracelet.
It is recommended to use plastic hammer to drive pins back in or you will scratch or damage bracelet. If plastic hammer is not available use an old toothbrush handle (or some plastic item) as an absorber. Simply put pin into the hole as deep as you can with your fingers, put the toothbrush handle on split pin end and hit handle, not the pin.
Make sure that pin ends are flush with bracelet. If needed- hit few more times.
Job done!
If you do not want to do it yourself, any jeweler will do it in a matter of few minutes.
Don't forget to rate, please.
Posted on Mar 19, 2009
escapement
Arturs Kalnins
  • 2338 Answers
SOURCE: Adjust watch band for Seiko 7T94 Stanless Steel Band
Job done!
Posted on Apr 04, 2009
David Tolond
  • 2501 Answers
SOURCE: How do I adjust my watch band?
If you want to deuce the size of your band then I have found some instructions on the Fossil website and since most watches are very similar you can try the method described there.
If you need to replace links then you can get them for Skagen (free!).
Go to "fossil.com", go to the bottom of the page and you will see a menu, click on "customer care", and then look under "Product Info" on the left and you will see "watch instructions"
Go down the list to the bottom and under "Phillipe Stark" there is an item "bracelet instructions"
Posted on Feb 14, 2010
Jimmy Accardi
  • 101 Answers
SOURCE: My Casio watch band has split apart where the
are you referring to casio mtg900 if so do you mean the rubber part below the G button . If so I do believe casio sells that first link . You can call them if you would like to order it if they still have in stock or for a whole new band
you can see the parts store here
http://www.pacparts.com/model.cfm?CFID=3663724&CFTOKEN=19469938&mfg=CASIO&model_id=MTG900DA-9V&row_start=1&src_model_id=mtg-900&action=list_part
I believe the 12 h and 6 h are the parts you are looking for I am not sure what side you need 12 oclock or 6 oclock , but give them a call they should be able to help you out
the other company that handles watch parts is here
http://www.americanperfit.com/parts/parts.htm
Posted on Oct 26, 2010
What type/kind of battery do i use to replace in my super hero ii ss black nixon watch
Take your Nixon watch to a jeweler to have the battery replaced.
Apr 24, 2017 | Nixon Watches
COULD YOU HELP ME PLEASE
You should take the watch to a local jeweler / watch repair shop in your area that deals with that brand. If not, contact Nixon by this link-
http://online.nixon.com/us/en/repair-center
Aug 23, 2016 | Nixon Watches Mens The Graduate SS Watch...
User manual for nixon delta pu watch
Here you go,
http://www.nixon.com/manuals/nixon_delta.pdf
Apr 07, 2012 | Nixon Delta II stainless steel PU Digital...
Hello! I just need some extra links for this
Contact your closest Nixon Service Center and we'll do what we can to resolve the problem. If you're in North America, visit our Online Repair Center or call us at 888-455-9200 from 8 to 5 pacific time, Monday to Friday, and we'll talk you through a solution or get you a service authorization number. Watches sent back to us without a service authorization number will not receive service. If you're somewhere else in the world, please go to the nixonnow.com homepage, select your country, then support/service for more details.
Note: Your warranty is not void if you do not register your watch.
Once we get your watch, please allow up to 10 business days for it to be processed. If you used our online service tool to send in your watch, you will receive an email notification from the Nixon Service Center when your package is received and when it is sent out. If you're in North America, we can provide you with the current status of your watch by emailing us at repaircenter@nixonnow.com or calling us at 1-888-455-9200 to talk to a Customer Service Representative.
Bands, straps and bracelets are not covered under warranty. Watches need to be sent in to the Nixon Service Center for band replacement. If you're in North America, visit our Online Repair Center and tell us how we can service your watch. You will then receive a service order number with shipping instructions. You may also call us at 1-888-455-9200 from 8 to 5 pacific time, Monday to Friday, and we'll set you up with a service authorization number. If you're somewhere else in the world, please go to the nixonnow.com homepage, select your country, then support/service for more details.
Please call our Service Center at 888-455-9200 for technical assistance on your watch. One of our representatives can assist you with setting your watch, answering any questions on watch functionality, or walking you through a solution for any technical issues with your watch.
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Mar 24, 2011 | Nixon Banks Watch for Men
Lookn for the wristband for the venture
Follow this link: http://www.nixonnow.com/service/faq.html Scroll down and read HOW DO I GET NEW BAND. Rate me, please.
Feb 16, 2010 | Nixon Venture Dial / Stainless Steel Band...
Time
Hi Terena,
You're not a numpty! :O
Just go here:
http://uk.nixonnow.com/home/
MouseOver 'Support' and click 'User Manual', choose your model and follow the instructions to set your watch.
Hope this helps!
Chris (ziraffa)
Dec 26, 2008 | Nixon Key Men's Watch - Gunmetal Dial -...
Nixon Watch band
Jul 01, 2007 | Nixon El Dorado NIX0010 Wrist Watch
Watches Logo
74 people viewed this question
Top Nixon Watches Experts
Janelle Schoonover
Janelle Schoonover
rhodesworks
ray gallant
ray gallant
Are you a Nixon Watch Expert? Answer questions, earn points and help others
