Computers & Internet Logo
R
Raymond Carver Posted on Jan 31, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Trying to open my emachines DVD/CD drive that is stuck shut
I have an Emachines Desktop PC, and the vertical DVD/CD drive is stuck shut with a DVD inside. I Need help getting it to open.
goneforever.
Level 3:
Top Expert:
  • eMachines Master 14,531 Answers
  • Posted on Jan 22, 2022
goneforever.
eMachines Master
Level 3:
Top Expert:
Answers
14531
Questions
0
Helped
3263893
Points
66315
Well lay the PC on its side do disk is up.
not shake it a see is eject button works
most driver, have the hail Mary pin hole there for the paper clip eject tub some of these confounding vertcles have non
so must now be dismantled.
NO PC told at all, model , one one clue.
must be think cased mini desktops, infamous for that.
EL1200?
the other kind is there is no tray like my Sony PS3.
it a grab out of the hand ODD,
if kids put 2 disks in side it is now jammed.
and must be dismantled,
el1200 has front trap door, that drops down and the see
a Laptop classic drive and the PIN hole see that./
NO PC told so crazy long answers all 3 technologies told.
5 Related Answers
Anonymous
  • 492 Answers
  • Posted on Mar 08, 2008
SOURCE: how to connect my eMachines W5243 Desktop PC to my basic sharp tv
This requires an svideo or composite output. You may have to buy a special adapter or card.
Anonymous
  • 458 Answers
  • Posted on May 29, 2008
SOURCE: Emachines T3882 desktop w/one cd-dvd combo drive[no floppy]
Download the drive test for the hard drive. Put the drive in your other computer and run the test. If it test good on simple test do the long test. IF IT COMES OUT FINE, Run the Zero program and then try to install the O.S. Check your BIOS settings and make sure everything is set right. You are on the right track. You just did not know how to test the drive. If it is a Toshiba you will not find a hard drive test. You might be able to use the Maxtor or Seagate drive test. Use the windows version if you can. If you can't do any of the test, right click on the drive and check for errors.
Rate me if this helped.
Anonymous
  • 1124 Answers
  • Posted on Nov 15, 2008
SOURCE: Don't know how to reformat my emachine T5010 desktop PC
Reformatting your Windows computer is usually the absolute last resort and is often done unnecessarily. Before you go through the process of doing a reformat of your hard drive please take a few moments to read through the rest of our website. If you are reformatting to fix problems with your Windows computer it's possible that by using some of the tips on our site, or by downloading or purchasing some of the tools or products that we link to, you might be able to avoid the need to reformat your computer. Because doing a complete reformat of your computer will erase the contents of the hard drive and require you to reinstall all software, reformatting is usually a last resort. Some Computer Manufacturers Make Reformatting EasyMany name-brand PC manufacturers include a restore-disk which makes it easy to reformat your PC and return it to the state it was in on the day you purchased it. Some manufactures supply only a standard Microsoft Windows CD, and some (usually lower-end PC manufacturers) supply neither! If your PC did not come with a restore or reformatting CD, then you will need to take extra steps to format your hard drive and get Windows re-installed. Back Up Your Files Before You Reformat Your Windows PC!Because the reformat or restore process erases everything on your computer, it is critical to have a backup of any important files on your computer. You will also need your original software install disks to reinstall any software you have purchased.
Things to do before you reformat your PC hard drive
  • Write down or print out all notes and internet pages because once the format process begins, you will no longer have access to them (or anything else in the PC)
  • As already stated, BACKUP all important files and data! When you reformat your computer everything will be erased!
  • Make sure you have all the CDs and other software. All programs will have to be reinstalled after you format the hard drive. Don't forget about software that came with hardware such as printers, scanners, etc.
  • Write down the brand and information for all the hardware on your computer. Look in the Device Manager and make note of the brand and model of network adaptors, video cards, sound cards, printers, modems, and displays. After reformatting you might need this information to reinstall drivers.
Anonymous
  • 62 Answers
  • Posted on Mar 07, 2009
SOURCE: INSTALL XP ON EMACHINES M6811 WITHOUT CD
If you have another pc, network the two and share the cd drive of the other PC
Anonymous
  • 21 Answers
  • Posted on May 09, 2010
SOURCE: My Toshiba ts-h653 cd/dvd RW drive failed. the
If the drive is trashed, just force the drawer open. If you don't want to do that, you should be able to disassemble the drive enough to get the disk out by removing screws... Sometimes the screws are underneath stickers, or warranty stickers, etc etc.
2helpful
My Lite-ON Combo SOHC-4836V DVD/CD-RW Drive will not open, is there any way to fix this? Expected Action: CD Tray opens What Happens: The sound of it trying to open, then the sound of it closing....
It sounds like a mechanical failure of the drive tray.
Use a un-bent paper clip and stick it in the tiny hole near the tray of the drive to attempt to prod the tray out of the drive.
Most likely there is something (a CD probably) stuck in the drive.
It may take a good deal of jiggling and bumping of the drive to get whatever is blocking it to come free. Be patient but firm.
2answers
Disc stuck in dvd drive. tries to spin. won't eject. (emachines desktop with xp home
There is a small pin hole below the tray. Straighten a paper clip and gently push it in this hole. The tray will unlock and pop out slightly, then pull the tray out and remove the DVD disc.
2helpful
Emachines 180 desktop reinstalling windows xp
Your trying to reinstall Windows XP from cd on your emahcine computer and from what I understand part of the way through the installation of XP you recieve a blue screen? Am I correct?
If so then their can be a couple of things wrong here.
One your cd drive is not reading the cd correctly try cleaning the lense on your cd drive or change the drive and use a different drive. Second your Windows XP cd is bad, screatched or smudged. Try cleaning your cd or make a copy of it on a friends machine and use the new one. If you tried all of these and you are still getting the blue screen repost for more help.
Thanks
1helpful
I have a Emachines t3522 W/ 4gb of ram, a 256mb ati X1300 pro but my disk drive won't open. It kills to get games in. Morse code is what it's like to press the button to get the drive to open. HELP!
Unfold a large paper clip and look for a small pinhole under the tray(the part that opens to put your cd in). Put the paper clip into the hole and push firmly. CD/DVD tray will open.
Also you can try going to my computer then right click on your cd/dvd rom icon. Then left click on eject.
Hank
Closing cd/dvd drive shuts system down
guess this problem is mainly due to defect in the driver .. try to reinstall the drive and check out
Emachine t6216 cd rom wont read
update your driver software for the cd/dvd drive that you have just go to the emachine support website lookup your computer and download the drivers for the drives if that doesnt work it might be a loose connection in the case open the case and make sure all the connections in the case are connected tight and right to the cd/dvd drive
Dvd drive no longer plays dvds on emachines T3410
When the CD/Dvd Drive becomes old the Optical Lense is not strong enought to read DVD because DVD is more dense than CD track. You can Try to clean the lense. There are lense cleaner available on the market.
CD and DVD drives
cd rom drives are pretty straightforward. if they dont open, there's no way to fix it since the units are non user serviceable. replacement is the only option. :)
2answers
Files off my discs wont open or copy to my new pc
on these matter i have identified two possible cause of your problems.
1. You CD/DVD (discs) maybe damage.
2. Your CD/DVD rom was not able to read.
Solution:
1. to sure that the DVD/CD rom is functional try other discs (Any discs that that is clean and no traces of damage.(if work on another discs so DVD/CD rom is good if don't work your discs is good)
if not solve the problem maybe your system had a problem. update me in case.
Top eMachines Computers & Internet Experts
Andrew Chrostek
Andrew Chrostek
Level 1 Expert
Are you an eMachines Computer and Internet Expert? Answer questions, earn points and help others
