19 year old Bosch Dishwasher, no warm/hot water going though cycle. Control knob manually advanced past 5 o'clock (wash), since it will stay there and not advance. Is it most likely the thermostat, heater assembly or something else? Please advise.
I find it unusual for water to be cold since it should only be hooked up to a hot water source. Start your dishwasher by running the cold water out of the kitchen faucet first then turn on the dishwasher so it draws in hot water from the start. The same way you take a shower.
The 5 o’clock timer can be changed. First select a different wash program by using the buttons. Now turn the knob until it corresponds to the new cycle.
It is most likely that it is failing due to old age and needs to be replaced.
SOURCE: Kenmore 80 Series Won't advance to spin
You will need to replace the timer. Let me explain why;
After the agitation cycle, the machine will enter a drain mode where the basket will not spin, only drain. After some time, the timer should 'pause' causing the machine to engage the spin clutch. The timer contact has become stuck, not allowing the pause, thus never entering engaging the spin clutch.
SOURCE: Frigidaire top load washer won't rinse
this can be two issues. One could be the control knob. there could be a malfunction here. secondly, you may have a faulty water valve assembly. the relay or solenoid may need to be replaced. i would start with the control knob.
SOURCE: Kenmore washer Model # 110.26852504 Cycle control knob?
You gotta pull out a rod behind the timer and that releases the knob. The rod when pushed into the timer spreads the shaft and holds it on there. To get to the innards you gotta flip up the controls. I have a cool video that shows how
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
SOURCE: Kenmore 70 Series Washer Won't advance in the
Bad timer. Try to find a used one if possible, this item is a little expensive.
SOURCE: washer stops after aggatating and wont drain
My Kenmore 70Series washer goes through the wash cycle then just stops when it is to drain and then spin.
