Washing Machines Logo
RENISH R GAMI Posted on Jan 30, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My topload washing machine IFB SDG 8 KG AQUA MODEL has displaying an error code that contain DOORERR which stop the other procedure of the machine it stop after one process & stop it.kindly give me advice to how to fix that problem?
Cherwally
Level 2:
Sergeant:
Habit-Forming:
  • Expert 156 Answers
  • Posted on Jan 30, 2019
Cherwally
Expert
Level 2:
Sergeant:
Habit-Forming:
Answers
156
Questions
Helped
62118
Points
619
Recheck the door, seems is not closing well enough
5 Related Answers
Anonymous
  • 706 Answers
  • Posted on Aug 17, 2008
SOURCE: LG-Trom Getting error CL .now not able to operate.after switch on it gives CL in display
IE is a water inlet error...meaning that the correct water level was not achieved within 8 minutes or it did not reach preset water level within 25 minutes...
CL is child lock feature which can be toggled on and off by by holding the Pre wash button in for 3 seconds.. Hope that helps...
Anonymous
  • Posted on Nov 11, 2008
Hai Idiots
ITs on CL (Child lock)
This occurs only if the power is turned off during the washing period
Press the TEMP and OPTION together for 3 seconds and it will go off
Amber
Anonymous
  • Posted on Feb 13, 2009
SOURCE: Error code 8 on Hoover vision hd 9 kg frontloader. No Manual.
Had same problem wouldnt spin found clip on motor had come loose pushed it back on problem solved!
Anonymous
  • Posted on Jun 02, 2010
SOURCE: Kenmore Elite Washing machine error codes
I am getting the code f 21 what does this mean
kel1guy2002
Kelly
  • 3740 Answers
  • Posted on Jun 09, 2011
SOURCE: How to fix error f
Hi and weclome to FixYa, I am Kelly
An F54 code is a motor over current fault. This is caused by a severe load on the motor or a bad motor bearing.
To remove the error press Pause/Cancel twice. Before removing the error.. try and find out why the motor is hard to turn. There may be an article of clothing stuck at the top of the inner tub or between the inner and outer tub. (
If the unit has previously had an ld code (long Drain) this can also cause high motor currents if the water level switch allows the washer to spin when not completely empty. Usually an ld code is associated with something stuck in the pump / pump inlet or possibly a bad pump.
Thanks for choosing FixYa,
Kelly
Hi, Our washing machine (IFB frond load senetor Aqua) is stuck at function disable Child lock and not not getting reset.it is stuck from yesterday
Look for two key pad buttons with a line with a smiling child face padlock symbol. Press and hold these two buttons until you see or here a response from the washing machine.
On a 8 Kg model, press and hold + and - Change buttons on the right of the LCD screen simultaneously for several seconds? That's the way to toggle the child lock on and off for this IFB model, https://www.amazon.in/IFB-Fully-Automatic-Senator-Aqua-SX/dp/B00LAXLN5C . On a 6Kg machine, https://www.amazon.in/IFB-Fully-Automatic-Diva-Aqua-SX/dp/B071G3B81W/ref=psdc_1380369031_t3_B00LAXLN5C , the appropriate buttons to hold are the Rapid Wash and No Cold. (These are on the right side of the control panel but to the left of the power button.)
Depending on the machine, the time to hold the buttons may be 3 seconds, 5 second or 10 seconds. You should see and hear some response. However, holding the key pad buttons for too long may re-enable the child lock.
I hope this helps. The child lock on most washers remains active even when the power is removed from the machine. This keeps the program from being activated when you clean the control panel or by a child who shouldn't access the machine. If the problem persists, I suggest checking for a problem with the keypad wiring or contacts.
2answers
How to solve ach1 error in ifb topload washing machine
If input voltage is too high then AC H1 error will come. So wait for sometime to stabilize the voltage then washing machine will start automatically. If not then call to your electrician to solve the power fluctuations
Laundry load is unbalanced. If laundry load is small. It can lead to an unbalanced condition. Add 1-2 similar items to help balance the load and rearrange load to allow proper spinning.
My IFB washing machine displays CH, What is the error?
On some IFB washers, the CH indicates that the child lock (control panel lock) has been activated to avoid accidental washer use. On the IFB digital 5 KG washer, you can toggle the child lock on and off by pressing the Soak Option and Delay Start buttons simultaneously. These are the second and fourth button for the Optional settings above the LCD display on this model. Below the keys, there is a skeleton key symbol in the center of a line drawn between these two keys. You can see this information in the manual for this machine in the manual, http://www.ifbindustries.com/home_appliances/washing/manuals_new/DIGITAL_5_KGS.pdf . See page 9 (7 of the PDF) and page 13 (page 11 of the PDF).
I hope this helps. Please add a comment with your model number for information specific to your washer. If your washer uses a different set of keys to toggle the child lock on and off, you should look for the skeleton key symbol on the control panel housing. Any response to a follow-up comment may be delayed.
4answers
I have IFB washing machine it shows E7 error
Our experienced and skilled technicians are excellent to repair the IFB Washing machine, not only IFB; they will repair all reasonable brands of Washing machines. Our IFB Washing machine Service Center can offer the services within the Hyderabad and Secunderabad zones. We can provide Doorstep service with reasonable cost. call us at 9133356801 & 9133356802. http://aktechnoservice.com/ifb-washing-machine-service-center-in-hyderabad
ifb washing machine service center hyderabad-hgqlgbgiqjunocffergste0f-5-0.jpg
1helpful
2answers
1helpful
2answers
In IFB front washingmechain AC h1 error is coming what to do
that error occurring due to high voltage in your residing area. We believe IFB Washing Machine protects your machine by tripping. We have GA 400 Voltage Stabilizer to buck or Lower your upcoming Voltage from GEB. It has Capacity of 12 amp and 15 to 20 Voltage up /down capacity. We are sure this GA 400 model will solve your problem. You can Call on : 9722658052 or 9427347880 Thank You
Top IFB Washing Machines Experts
ADMIN Andrew
ADMIN Andrew
Aron
Are you an IFB Washing Machine Expert? Answer questions, earn points and help others
