Your motor has a couple of screws to hold the tension on the belt. Loosen them and pull the belt off and then remove the belt off of the hand wheel. Put the new one on. While you are moving the motor to adjust tension on the belt you should have the motor running so that you can adjust where the motor has the least resistance.
SOURCE: need manual for vintage singer fashion mate 223 sewing machine
www.ismacs.net is a helpful site with some links for manuals to vintage sewing machines. It will give you the singer co. link to print a manual from.
SOURCE: HOW TO FIX SINGER SEWING MACHINE MODEL 223; GREASE
Make sure no thread is caught in shuttle, or around bobbin case, etc. Check "plate teeth" also. Manually turn handle/wheel to engage and slow press pedal.
Is there a burning smell of rubber? Bad motor. Check warranty.
