Question about Frigidaire Ovens
How to remove oven door to a frigidaire Pro Series double oven model # PLEB30T9DCC
6ya staff
SOURCE:
reg501
Richard
  • 413 Answers
SOURCE: Trying to remove front doors from Frigidaire Double oven.
Open the door fully and with a small screw driver, look closely at the hinge area on the oven cavity. There you will see a small lever that will rotate down and lock the door in place. Once in the locked position, begin closing door, you will feel the door 'catch' then lift the door off of the oven.
The door can now be disassembled and cleaned.
Posted on Jun 22, 2008
aborcass
Ron Coons
  • 2651 Answers
SOURCE: how to remove oven door on kitchenaaide pro line double oven
your manula will explain how to remove door, depending on age, there is/or may be a locking mechinism at base of hinge, which youll need to "lock" and then the door itself simpply lifts off. unlocking the hinge only after reinstallling the door
Posted on Feb 09, 2010
ginko
Ginko
  • 19396 Answers
SOURCE: how do I remove the oven door of Frigidaire Model
Hi.
You have to open the door all the way through.
Then remove the two locks from the hinges.Pull the tabs out, help yourself with a screwdriver.
Grab the door firmly on both sides, pull up the top of the door and slide it out.
Here all diagrams and parts for your appliance.
Regards.
Posted on Mar 04, 2010
MNfisherman
Nate Stansfield
  • 11896 Answers
SOURCE: I have a double wall
The problem your oven is having is an all to commonly occurring problem with the self-cleaning functions.
Possible solutions are listed below.
Use those that apply to the existing condition your having.
Try removing the electric cord from the wall socket. Leave the oven and or entire stove unplugged for several hours before plugging it back into the electric power. By doing so, this may release the locking device.
If that fails, once again unplug the appliance, try using a thin blade knife or screw driver to release the lock by entering through the latch lever space between the door and the ovens outer frame.
If this method fails, you may have to remove the entire glass front panel and access the locking device from inside the cabinet.
Before attempting any repairs, first, check ALL the function control settings, on the front panel. Doing this is only to verify that all control selections are set correctly.
Try every optional setting possible, in an attempt to verify that no optional selection, setting and or condition has been overlooked which may be possibly causing the problem.
If all the above is determined to be accurately and correctly set, most likely the micro switch, in the door locking mechanism, which activates the self-clean cycle is stuck, even though the lever is released and the door opens.
What your likely going to need to do is remove a cover plate or panel which covers the locking device, in the ovens door frame {not in the door} and attempt to manually release the locking device and or tiny micro switch.
CAUTION:
Be careful doing this. The appliance must NOT be plugged into the electrical power source!!!!
If it is not possible to determined exactly how to release the mechanical locking device, removing the wires attached to the tiny micro switch may be necessary. If you do remove the wires, be sure to use electrical tape to wrap the wire terminal ends to prevent any possible electrical shorts or electrical groundings.
Should the wires need to be removed and it does solve the problem, you then have two other choices. Leave the wires unattached, reassemble the access part or parts removed and continue to use the oven without using the self-cleaning cycle again.
Have that self-cleaning function fixed by a service professional when some other operational function fails and a service representative is needed to correct that condition. In this manner, two inoperative conditions can be corrected with one in home service call.
Posted on Oct 07, 2010
Oloyede Monsuru
  • 1417 Answers
SOURCE: I have a frigidaire oven M# PLEB30T9DCC. It's a
IF you can locate the model number tag (bottom left of door opening) you can look up the manual at www.geappliances.com
The only button on your stove that should make the door lock would be the clean button (self clean model) if that is pressed simply hit the clear/off or cancel key and wait for the door to unlock.
IF the self clean option ran for an hour or so, you will have to wait for the oven to cool down before the lock can unlock (safety feature).
These codes mean that the oven's electronic control has detected a condition it needs to check. When you see a code, follow these steps:
  • Press "Stop/Clear" to clear the display and stop the beeping.
  • Reprogram the oven.
  • If the code still displays, turn off the power to the oven at your breaker box and wait five minutes before turning it back on.
hope this help?
Thanks for using fixay
Posted on Oct 27, 2010
Frigidaire double wall oven clean between the glass
Remove door off the hinges. Unscrew the handle and screws at the bottom. Carefully separate the outer panel from the frame
Apr 09, 2014 | Frigidaire 27 in. Electric Gallery Pro...
How do you remove the door from a frigidaire gallery series double wall oven(self cleaning)?
Open the door and look at the hinges the connect the oven door to the oven body, on each side you will notice a piece that can be moved back and forth without moving the door, roll each side toward the oven body this should be the locked position, now try to close the door and you will notice the hinges lift up. At this time you need to pull up and push forward on the door and both hinges will come out.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
Apr 24, 2012 | Frigidaire 30 in. Electric Gallery Series...
I JUST WANT TO REMOVE THE OVEN DOOR TO CLEAN THE INTERIOR SURFACE OF THE DOOR GLASS
If you mean between the inner and outer panes of glass; you will regret it. It's likely that both are mounted with a fragile heat-proof mineral (non-asbestos) gasket material that may crumble once the panes expose it.
Apr 22, 2011 | Frigidaire 30 in. Electric Gallery Pro...
How do I remove the oven door of Frigidaire Model
Hi.
Regards.
Mar 04, 2010 | Frigidaire GLEB30T8A Electric Double Oven
I have a Frigidaire Gallery Oven Professional Series, I don't have the model number. In trying to self clean my oven, I accidentally pressed something that engaged the oven door lock. Now I can't close...
If your oven door has gotten bent or warped (maybe you rested something heavy on it…), you need to remove the door, disassemble it, and straighten it. You can lift most oven doors off of their hinges by opening the door several inches to its first "stop," and lifting the entire door straight up.
If the hinges have become worn, damaged, or bent, you probably need to replace them. I recommend replacing both hinges at the same time, to prevent uneven wear of the undamaged hinge.
Sep 04, 2009 | Ovens
How to unlock the frigidaire oven range door and remove error F3?
How do you adjust the oven door on a Fridgedaire Gallery Series gas stove?
Jul 13, 2009 | Frigidaire 30 in. Electric Gallery Series...
Jun 22, 2008 | Frigidaire Ovens
Ovens Logo
316 people viewed this question
Top Frigidaire Ovens Experts
Marvin
Marvin
Bruce Denton
Alan Chouinard
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
