This is straight from the repair manual.
204 Final rinse time Parameter 4 ... 30 s. 7 Duration of booster pump activation (running time limited by P306!!).
306 Maximum final rinse time Parameter 0 ... 30 sec. Maximum booster pump running time (rinse) (limit of P204)
Booster heater pump does not work Check power supply to power rinse pump. Check pump rotor and replace 203/204 pump if necessary. Check start capacitor and replace if necessary.
Hope this is of some help.
SOURCE: dishwasher fix
111
Floor pan Leakage
Leak inside machine activating ground float switch
302
At pumping out during rinse cycle level does not fall below level 1
Drain pump faulty, blocked, aqua stop not closing completely, no signal from circuit board (connection number 6 on XA1 connection plug)
SOURCE: LE error after machine fills with water
LE actually stands for "Lock (motor) error". The main pump motor is probably bad. It is able to drain because that is a different pump motor. If it was a problem with how the drain hose was run and it was draining out you would get a DE error "drain error".
SOURCE: Ge Triton XL Dishwasher Fill Problem
I would check your fill valve screen, where your water line connects to
the dishwasher, lots of times i will see that screen clogged,
especially on customers homes that have wells.
There is no way to change the fill time on these.
There is also the potential problem with the float sticking if it is gunked up it will not allow water in...see that it moves up and down freely and you should here a clicking noise.....If it is not one of these there could be a problem...with the timer...I am providing a link that will help walk you through this problem in a more technical...manner...if you are not comfortable performing these tests...i suggest you forego it and let a tech handle it....
http://www.applianceaid.com/dish.html#filling (http://www.applianceaid.com/dish.html#filling)
this is one continuous link.....you can scroll down until you see the won't issue.
I hope this helps ..good luck, have a good day& please rate my effort......The Fang
SOURCE: i need an instruction manual for meiko ecostar 530f dishwasher
Go here and see if your manual is there...I hope this helps...thanks for rating my effort.....The Fang
http://www.meiko.us/downloads.htm
SOURCE: Kitchen Aid dishwasher model KDC-18 is not filling with water
Under the machine is the water inlet valve. if you take off the front end of that you find a filter which fills up with rust, and you can clean it out. If that doesnt work, repairclinic.com will sell you a new valve for 32
