Hey I had a similar problem with our heater/AC unit at home. It turned out to be the battery backup in the thermostat. I put in a new battery and all was good. If you can get and post the make and model number of your unit, that will get you some better info and ideas to help you out. Have a good one.
Look up - online - for the instruction manual for "this unit" (as you described it).
if you only knew the make and model number and had told us what type of unit it is, someone might be able to give you a better answer.
with all due respect, regards.
Testimonial: "I have a Comfortmaker C9MVX060F12A"
SOURCE: york hvac heat problem
whats happenening is that the unit's nare probably going off on the high limits. Thats when the fans will run until they are cycled off manually. Check yor filters and the belts to make sure that you are moveiong enough air for the unit. theanks for usin Fixya.
SOURCE: ruud silhouette #UHDG-07EAUER won't heat house
Cleaning the flame sensor has nothing to do with blower motor not turning on. You either one of the following problems 1 bad cap for motor. 2 bad motor. 3 bad limit on blower housing or 4 a bad board. You will need a volt meter to check for these problems. Try seeing if the fans runs with unit of and fan switch turned to on. Also does motor hummmm. Is motor cage free ( can check by manually turning) If motor doesnt humm and the cage is free wheeling then you will need to find out if you have power going to the motor. If you find out that you do then you will need to change blower motor. If you do not have power then you will need to check limit with continuity tester on volt meter. If that checks fine only 1 thing can be wrong and that is the board.
SOURCE: Kenmore gas dryer #110.7732792 is making buzz/hum
Check for blockage in your lint trap and the hose running to the outside of the house
SOURCE: I found the Bryant furnace 395cav048090 calling
If you do not see a bright light before the gas releases, your ignitor is probably out. If you disconnect, you should measure ohms from the two ignitor leads. If you do not measure any, it is open and will not work. You will usually see a mark of white on the ignitor. Another possibility is the circuit board may not be sending the required voltage to ignite the ignitor so you'll want to check that too.
