SOURCE: Melted turntable support
Yes, that's part # WB06X10138 (coupler) and you can get it here.
You will need to remove the bottom cover of the microwave and remove the turntable motor to get the new coupler in.
We're happy to help and we appreciate your thoughtful rating of our answer.
SOURCE: Emerson microwave Glass turntable replacement
check with www.microwaveglasstrays.com or call them @ 1-877-894-0035 toll free
toll free 1-877-894-0035
SOURCE: Plastic piece for turning turntable has partial meleted.
This is a pretty simple, inexpensive fix,
The best place to order
parts for this brand is Encompass (formerly Tritronics).
If you don't find the part on their Web site, I would call them with your model number. They are toll-free at 866-779-5835.
We're
happy to help you with free advice and we'd appreciate your
SOURCE: turntable will not turn with glass turntable on it
Make sure the platter is correctly seated on the plastic drive. Now gently press down on the platter and see if it resists turning. If the platter turned easily, the plastic drive is spinning on the motor shaft and needs replaced. If the platter resists movement, the motor under the floor needs to be replaced.To replace either part visit the web site www.partsdirect.com If you found any of these suggestions helpful, please rate my solution. D. Lange
