Question about GE Televison & Video
I need the tv code for a universal remote, im reaaaaalllly sick of getting up and changing the channel myself
  • kira_lynn16 Aug 06, 2009
    the remote is a 3 code remote, a philips, the tv is a 1999 model and the code for it is 25gt239 please help!!
  • 736 Answers
We would have to know the model number of the tv and the universal remote to give you a number ... the older universal remotes have a 3 digit code .. i have found many things that dont work with these ... the newer ones have a 4 digit code and work (or partiallly work) with a lot more products.. the code list comes with the remote or sometimes you can get them over the internet .. .. i do have the list for older and newer GE remotes .. there are many codes for various models of GE televisions .. so you need a model number .. at least how old it is .. and what remote you are using .. i will look .. maybe there are few enough codes that i can publish them all .. you would have to try them one at a time ...
Posted on Aug 05, 2009
Anonymous
SOURCE:
I have lost the remote and im trying to program a universal remote to it but the codes arent working. Also the tv will not change channels. What codes do i use?
try the scan all / some tvs take a universal 4digit code/ but most old tvs are 3 digit and pound shop remotes are all 3 digit
look at book to scan all/dont enter a code when tv goes on or off press power button dep on remote
Nov 30, 2009 | Televison & Video
I have a phillips CL034 universal remote need code for sharp tv
this should work:
SETTING CODES
HOLD THE CODE SEARCH BUTTON DOWN UNTIL THE RED LIGHT STAYS LIT.
PRESS THE DEVICE BUTTON (ie TV)
CHANNEL UP BUTTON UNTIL THE CHANNEL CHANGES. (300 SHOULD BE MAXIMUM)
PRESS THE MUTE BUTTON TO SET THE CODE
Oct 19, 2009 | Philips Magnavox Learning Universal Remote
Need code to program philips universal remote
most philips universal remotes have the "code search" option this is done by:
1: Manually turn on ur tv
2:hold setup untill red indicator stays on and release button
3: press and quickly release what you wanna program (i.e tv,vcr,ect.)
4:press channel up repeatedly untill your t.v changes channels(up to 300 times) if you over shoot the channel change press down til it changes again.
5: press and release MUTE to install the code.
Jun 17, 2009 | RCA Universal Remote Control
T.v. remote codes
Yes the GE universal remote #24914 works to change your Ilo tv from analog to digital and switch to vid1 or vid2 ect.... The code is in the book that comes with the remote. I use this remote myself. This remote can be bought at Target for under $10.It works all the features.
Feb 27, 2009 | iLO IWT3206 TV
Activate RCA Universel Remote with Ascent
this may work for all universal remotes, im using the philips SRU3003/27 universal remote. it doesnt contain a code for my t.v., however after searching the internet n all that. i was able to program my tv. and heres how 1: Manually turn on ur tv 2:hold setup untill red indicator stays on and release button 3: press and quickly release what you wanna program (i.e tv,vcr,ect.) 4:press channel up repeatedly untill your t.v changes channels(up to 300 times) if you over shoot the channel change press down til it changes again. 5: press and release MUTE to install the code. i hope this helps for all those who have had to deal with these nice but annoying tv.s
Dec 05, 2008 | Televison & Video
No remote and cannot change to video mode!
Go to radio shack and get an universal remote control that has a tv/vcr input button. the one i got is a Phillips Universal to switch channels myself.
Sep 13, 2008 | Symphonic ST420FF 20" TV
Need codes for a philips universal remote code sheet
http://www.remotecodelist.com/remotes/magnavox/Philips-Magnavox_PM525S.pdf
This is the user's manual for a Phillips remote control. There is a list of codes in it. They should be rather universal. There's also instructions as to how to program it. I believe that there is a way to program it without using the codes.
Programming with Code Search
1. Manually turn on the device (TV, VCR, etc.) to be controlled.
2. Press and hold Code Search button until the red indicator stays on. Release the Code Search button.
3. Press and release the desired mode button (TV, VCR, etc.). The red indicator blink, then stays lit.
4. Press the Channel Up button repeatedly (up to 300 times) until the device could be controlled changes channel. The red indicator blinks, then stays lit. If you accidentally overshoot the code required, press the Channel Down button to backtrack through the library until the device changes channel. Pressing Channel Up changes direction to forward again. Press and release the Mute button to install the code.
Hope this helps :)
Jun 21, 2008 | Philips Magnavox Learning Universal Remote
Codes for ge universal
Universal remote codes change every year depending on what the most popular models are on the market. If you have tried "code search" and have been unable to lock-in a code for your device, this means a code for your model is not available in this remote. The memory chip in a universal remote can hold only a limited amount of information. There are no lists of models for each of the brands.
Oct 25, 2007 | GE JASRM24912 Remote Control
Lost Remote
I personally would get myself a "Universal Remote". These units will operate almost ANY unit that uses Infrared... Ya Punch a "Code" in for your particular TV etc, and thats it... total conrtol...
Sep 22, 2007 | Sharp 32R-S50 32" TV
After programming my new universal remote, the tv keeps changing chanels! wont stop!
you need to program your remote control. take the battaries out. and maually turn the tv on. then hit the source you want to view. for example, I want to control the tv set. I push, code search and hold it then push the source button and then release the source button and then release the code search button. now, aim at the tv and then keep pressing power button till it goes off. when the tv is off, hit return or set or something like that.( every remote has different calling for it but still the same function) it should work. try it and let me know.
Mar 06, 2007 | GE HO976855-Device Universal Remote with...
Televison & Video Logo
139 people viewed this question
Top GE Televison & Video Experts
matt martin
matt martin
Are you a GE Televison and Video Expert? Answer questions, earn points and help others
