SOURCE: My bosh maxx6 washing machine
hiya
you will need to phone bosch and get an engineer out as the machine will be under warranty for another 3 months.
if you call anyone else out or even try to fix it yourself you will void the warranty.
hope this helps
please dont forget to rate the helpfulness of this reply, thanks kj
SOURCE: my Bosh washing machine has excessive vibration.
it may be level but if the feet are not adjusted to be tight to the floor this will cause it to walk so try adjusting the feet then lock the locking nut I am sure you will find 2 that are not adjusted tight enough.
SOURCE: my bosh washing machine not washing.
It appears your timer/main controller/CCU has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!!!!
SOURCE: Our bosh Maxx 7 varioperfect washing machine buttons are not working Amd showing f:21 error
F21 error on this model of Bosch washing machine pertains to a motor or a control board fault. This can be reset and to reset it turn the appliance knob to the off or reset position (12 o'clock), turn the knob to the 6 o'clock and then press and hold the spin button, then while holding that button turn the knob to 7 o'clock position, continue holding spin button for 15 seconds and then turn the knob to off. After a minute turn it back on, if the error code is still there then it means that the motor or brushes in the motor should be replaced, though it is always better to replace the motor assembly completely.
