Televison & Video Logo
Posted on Aug 05, 2009
WHEN THE TV SET IS ON WE ARE HEARING A NIOSE.ITS NEW PURCHASED ONE
  • nonanon
    nonanon May 11, 2010
    What kind of noise is it making? From the speaker or elsewhere? Hum, hiss or what sound?
pudster11
Level 1:
Problem Solver:
  • Contributor 12 Answers
  • Posted on Aug 05, 2009
pudster11
Contributor
Level 1:
Problem Solver:
Answers
12
Questions
0
Helped
5615
Points
27
Alot of Plasma TVs will give you fan noise. If you look on the back you will see holes and fans inside
Wheel Bearing Niose?
Lift the tires off the ground and spin them and check for any play in the bearings. Look at your tires. If they have flat spots on the outter edges of the tire then that is probably the noise you are hearing.
2answers
Sansui 32 " with audio problem
Is there some sort of virtual surround activated?
1helpful
Purchased 20 inch monitor from Pc World last week.although the picture is o/k the sound system is .hardly any sound at all and I have turned the volume up.contacted AOC and they said these monitors are...
LCD speakers are really not that good, specially for smaller than 42". but it should not be that faint if your hardly hearing a sound, try to get a replacement unit.
What the humming sound in back of 2005 freestyle while driving
just had same problem in my 05 explorer and had the rear end replaced and it went away. im sure that its a bearing in the rear end if its the same niose i had. hard to say with out hearing it good luck.
LG 37LP1D - Buzzing niose coming from TV
I blew condensed air through the ventilation holes in the back of the TV, which greatly reduced the buzzing noise.
3helpful
2answers
TV Reset Problem
trying setting it on fire, let it burn for about a half hour then come back to it. should work like a champ then
5helpful
8answers
Akai LCT2715 Led blinking orange and set won't turn on
There are about 16 to 17 capacitors that are a common fail point on this TV. I can repair your power supply board with new high quality capacitors and recondition the board to work like new for $100 + S/H, you simply have to send me the power supply module and turn around is approx 2 days from the time I receive the package to the time its out the door. Approx 8 business days according to the delivery carrier you use.
Grand Canyon Tech
Grand Canyon Tech
Kolbrun...
