Why wont the bobbing catch on my meistergram pro 1500 machine. I have tried everyhting
SOURCE: Bottom thread will not catch
Unplug the machine and remove the needle plate so that the bobbin case if fully exposed. Lift out the bobbin case and the cup that it sets in will be visible. Locate the "hook" on this cup. It is a finger with a sharp point at the upper edge of the cup. The hook is what grabs the thread from the needle while sewing.
If the hook passes by the needle AFTER the eye of the needle is above it, you timing has slipped and the machine must be taken in for repair.
If the hook catches the thread from the needle, put everything back together and try threading again.
SOURCE: I cannot get the needle to catch the bobbin thread
sounds like your keeping the upper thread too tight when you drop your needle down to catch the bobbin or the bobbin thread that you left hang out is too short, let me know if it works amy
SOURCE: Singer 457 Zig Zag Sewing Machine not catching bobbin thread.
There are manuals avilable online to purchase for the singer machines, SOrry I was not able to locate a site that has them for free.
.... http://sewingonline.co.uk/singer-manuals.html
SOURCE: bobbin thread won't catch with needle thread
check that the needle is in the right way round i.e. with cut out on the needle facing into the machine. if this is fine then check that as the needle comes back up from the lowest point that it goes to, that the point on the bobbin case passes just above the hole in the needle, i.e. in the middle of the cut out.(if not it needs re timing) if threaded a small loop should appear at this point for the bottom bobbin to catch if not slacken the top thread and try again.
