SOURCE: phone freeze unlock code
you need first to have the phone unlock by taking it to a mobile store, then also have them firmware reflash on the phone.
my samsung z500 hang after 1 min it turn on. keypad and other thing does not work.
UNLOCK MOTOROLA SYNC
DO NOT TRY MORE THAN TWICE ... u can only do 3 attempts .. if the third don't work u will freeze your phone
Unlocking the Sync Instructions
The idea is that you are changing your phone's 8-digit unlock code to all zero's.
(1)Turn off your phone and remove the sim card.
(2)Then power the phone back on.
(3)Enter the following numbers on the keypad: *2767*3855# this will restart your phone,
(4)When your phone has restarted and powered back on you will enter the following into the keypad *7465625*638*00000000*00000000#
If your phone says wrong password, turn your phone off and put in an
unaccepted Sim Card into the phone (A sim card from another Service
Provider) and then start the process over again. If it says wrong
password even with the wrong Sim card, then you have reached your
second attempt, Do NOT try it again. Instead, go to Ebay and purchase
an unlock code.
(5)NEXT ENTER #7465625*638*00000000#
(6)AND THEN *#7465625# to check the locks....all locks should now be inactive or Off
If you find that some of your locks are still turned on, now
that you know your phone's unlock code, (00000000) you can use the
following codes to unlock individual locks on your phone (Where you see
the word Code you will put in your new unlock code, which is now
00000000:
#7465625*638*Code# = Disables Network lock
#7465625*782*Code# = Disables Subset lock
#7465625*77*Code# = Disables SP lock
#7465625*27*Code# = Disables CP lock
#7465625*746*Code# = Disables SIM lock
#7465625*228# = Activa lock OFF
SOURCE: how to unlock forgotten security code- please help me hurry! bebot
I was told that I could really have it unlocked but that would mean the messages in the phone would be all deleted-- I solved it by simply letting go that my Sister would not be able to recall her security code -- maybe one day, she would-- but at this time we do not want to erase the numbers inside the cell. So...we are just waiting!
thank you very much for following through. God bless you, Fix ya.
Hi ,
you can download unlock client from below site
http://www.mobile2mobile.net/unlock/Remo...
http://www.mobile2mobile.net/unlock/RemoteunlockingSamsung.htm?gclid=CLzQwIOBqYsCFQ-Wbgod2n3IjQ
PLEASE RATE ME...........................................
