Question about Nordic Track Exercise & Fitness
My norditrack treadmill stopped working in the middle of my workout.Before that happened all three fans increased to a speed above the highest speed.I then tried later worked but stopped again.
Still have no control over fan speed and the treadmill will not restart.
6ya staff
SOURCE:
Anonymous
  • 702 Answers
SOURCE: Fan speed switch only works on #5
Call your local GMC Dealer and see if they have the climate control panel in stock. What happens is the circuit board on the back of the panel shorts out. The panel comes as an assembly and is very easy to replace. Don't go with a wrecking yard piece. I made that mistake once and it didn't work either. I got one from the Chevy dealer and it worked perfectly.
Posted on Aug 21, 2008
hammerhead30
  • 6 Answers
SOURCE: 2002 Ford Taurus blower fan only works on high
fords are notorius for faulty fan switches, you will need to get a new one, but it will probably fail in a year or two.
Posted on Nov 11, 2008
Anonymous
  • 85 Answers
SOURCE: fan control switch
the blower resistor and pigtail will need to be replaced. good luck ive seen this problem a lot of times mr gm ha ha
Posted on Nov 23, 2008
Anonymous
  • 137 Answers
SOURCE: the blower fan speed control stopped working
usually a bad blower resistor is at fault...
Posted on Feb 05, 2009
shocktroop40
John DeCosta
  • 155 Answers
SOURCE: 2002 Honda Odyssey fan only works at high speed. The A/C compress
Usually when the blower fan only operates on hi speed, its because of a failed blower motor resistor. You still have hi speed because on hi, the power going to the blower motor goes directly to it, as opposed to the lower speeds, when the power is routed through the resistor, thus lowering the voltage, which in turn lowers the speed of the fan. The resistor is usually located near the blower motor itself, under the hood back near the firewall.
Posted on Aug 15, 2009
HELP! MY TREADMILL WILL AUTOMATICALLY CHANGE SPEEDS TO THE HIGHEST SPEED EVER. ITS INCREDIBLY TERRIFYING!
please RUN the software calibration inmediately, for easy diagnose and fix it. However adjust the speed sensor, clean it, test for open or fraulty, tight the connector very well.
Jun 06, 2013 | Epic Exercise & Fitness
The term immobilize is on the display panel and I want to start it up. How do I get it going again?
When necessary to immobilize the treadmill, set display to read SELECT A WORKOUT. (Press the STOP Key
twice if not already there). Then hold down the SPEED DOWN Key and press the STOP Key. The treadmill
now displays IMMOBILIZED. In this state, the treadmill cannot be operated. The main motor and incline are
disabled. The treadmill will remain in this state across resets, power cycles, etc. To restore normal operation,
repeat the same key sequence: hold down the SPEED DOWN Key and press the STOP Key. The treadmill will
display SELECT A WORKOUT again.
Apr 11, 2013 | Life Fitness T5-0 Treadmill Fitness...
The term immobilize is on the display panel, how do I get rid of that and get it working again
How does the e3200treadmill fat calories work with the regular calories burnt.
Add incline. Instead of keeping the treadmill on a flat surface, maintain an incline as you walk, jog or run. This will serve to replicate the wind resistance and terrain variation that you encounter when you run outdoors. Keep an incline of at least 1.5 percent on your treadmill throughout your workout.
  • 2 Increase your speed. If you run at the same speed every time you workout, your body will not be challenged and you may reach a fitness plateau. Up your speed by a quarter-mile per hour every few weeks.
  • 3 Vary your workout time. In order to challenge your body in different ways, variety is key. If you run for half an hour three times a week, opt for a one-hour run for your fourth workout. This will help to condition your body for endurance training, resulting in more calories burned.
  • 4 Use intervals. Interval training can dramatically increase your calorie burn in an average workout. Instead of running at a steady pace for your entire workout, mix in sprints. Jog at a steady pace for two minutes, and then increase your speed to a full sprint for 30 seconds. Return to the steady pace to recover. Your heart rate will rise on your intense sprint intervals and stabilize on your longer recovery periods.
  • 5 Incorporate incline into your interval training. You can use incline in the same manner that you would speed to interval train. Walk or jog at a 5 percent incline for two minutes. Increase the incline to 10 percent for two minutes and then to the 15 percent maximum for one minute. Decrease the incline back to 10 percent for two minutes and finally back to 5 percent for two minutes. Repeat this same pyramid interval a few times.
  • 6 Wear a heart rate monitor. This will monitor how hard you are actually working as well as how many calories you burn in each workout. You can then adjust your speed and incline accordingly to maximize your calorie burn.
  • 7 Drink plenty of water before, during and after your treadmill workout. If you are dehydrated, you won't perform as well as you can. You'll work harder and burn more calories if you're hydrated
  • Nov 03, 2011 | Exercise & Fitness
    I hae a Pro Form 540 Iteracive Trainer treadmill. When the key is inserted, the treadmill cuts on but the control panel doesn't seem to work when you touch start. I waited and cut it off and went...
    I will advice you try re-calibrate your treadmill, follow the procedure below to re-calibrate it,
    Step 1 Stand on the side rails of the treadmill for safety purposes. Remove the safety key. Step 2 Press and hold the two incline buttons. The incline buttons are blue and on the left side of the display. Hold the up and down button simultaneously. Release the buttons when the display reads "Calibration."
    Step 3 Press the green start button located either above or below the large, red stop button (depending on your model). Stay on the side rails as the treadmill belt begins to move. Both the speed and incline should go through their full range from lowest to highest, and then back down again.
    Step 4 Repeat the process if the display does not read "Calibration Successful."
    Aug 08, 2011 | Sport & Outdoor - Others
    Treadmill just stops in the middle of a workout.
    Probably is getting overheated.... Also, I have seen some models that stop the workout when the belt is getting too worn out.... Perhaps you should look into replacing the belt. If the screen is losing power too, then it is definitely power failure (in which case, you should examine all the cords and connections.
    Feb 28, 2011 | Proform Exercise & Fitness
    My NordicTrack EXP 1000 stops in the middle of a workout. Before it stops, I smell a rubber smell. 1) Does the tread need lubrication? 2) Is the motoer burning out?
    my nordic track 1000 stops several times during the workout. I can step to the side and the belt may or may not start back up. The display continues to display the set machine. any suggestions?
    Jan 03, 2010 | Nordic Track NordicTrack Treadmill, A2550
    Manual Treadmills vs. Motorized Treadmills
    Treadmills come in two basic varieties, just like lawnmowers: manual and motorized. But, unlike a lawnmower, you will generally get a better workout from a motorized treadmill. Manual Treadmills - Getting Going On a manual treadmill, the action of your feet against the deck moves the belt. Pros * You provide all of the motive power and exercise your lower body. Cons * It can be difficult to get the belt moving intially. That straining against the belt can stress your joints. * You may have to raise the incline of the treadmill significantly to make it easy enough to get the belt moving. * Once the belt is moving, however, you would have to stop and get off to change the incline, so you are stuck with one incline level during each workout. Motorized Treadmill Advantages * The belt is moved by the motor, you don't have to strain to start it. * On many treadmills, you can adjust the speed and incline while you are still walking or running. On others, you may have to get off and adjust the incline manually, but you just have to turn on the treadmill to start the belt again. Manual Treadmills - Speed With a manual treadmill, you go only as fast as you push yourself. If you slow, it slows. If you stop, it stops. Motorized Treadmill Speed and Workouts The speed is adjustable and many motorized treadmills have workout programs that adjust the speed to give you a varied workout. This pushes you to go faster. The constantly moving belt of a motorized treadmill motivates you to keep up. Costs Manual treadmills are relatively inexpensive, in the $100-200 US range. Motorized treadmills for home use cost from $750-$5000, and generally the more you pay, the better you get. Most motorized treadmills under $1000 have underpowered motors and are less sturdy and have fewer options for adjusting the incline, programmed workouts, etc.
    Dec 01, 2008 | Endurance TF3i Folding Treadmill
    Exercise & Fitness Logo
    73 people viewed this question
    Top Nordic Track Exercise & Fitness Experts
    Ross Metcalfe
    Ross Metcalfe
    Treadmill Repairs...
    Android Man
    Android Man
    Are you a Nordic Track Exercise and Fitnes Expert? Answer questions, earn points and help others
