Amazon Kindle Fire HD Logo
m
maryann covington Posted on Jan 15, 2019
My kindle will not charge - Amazon Kindle Fire HD
  • Repairlass1989 Oct 22, 2019
    Try a different cable or try plugging it in to USB port instead of plug
J Jno
Level 1:
New Friend:
Problem Solver:
  • Contributor 19 Answers
  • Posted on Jan 16, 2019
J Jno
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
19
Questions
0
Helped
2118
Points
50
Try to check first your cable charger
Karen O'Neill
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on Jan 15, 2019
Karen O'Neill
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
507
Points
6
Have you tried a new charger? New charger block? New outlet? Finally factory reset on Kindle?
2answers
My kindle won't charge. I have tried 3 different chargers.
Lillian, May have to try hard reset or possibly repair charge port to get battery to start charging. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
My Kindle won charge
Kindle Wont Start or Charge How to Reset Kindle
Troubleshooting Kindle Fire That Won Charge
Kindle Fire Won Charge Fix
Kindle will not shut off-goes to shut off or cancel but wont move. doesnt charge well-doesnt always hold charge
Patricia, Using the power switch, you can forcibly reset your Kindle device. This reset will shut down the Kindle without accessing the shutdown command from within the Kindle's operating system, a particularly useful tool when dealing with a frozen Kindle. To initiate a hard shutdown, Kindle disconnect from its charger, slide and hold the power switch for about 20 seconds. This will force the Kindle to shut down, now it can be restarted normally.
Check links below for charging problems.
Reset Kindle Fire When it Won Turn on or Charge
Kindle Fire not charging
9 common problems with the Kindle Fire HD and how to fix them
3answers
I can turn my kindle on but can't get any thing else to work.
Reset Kindle Fire When it Won't Turn on or Charge
www.lovemyfire.com > Kindle Fire Problems
However, sometimes when it locks up you can't tell because the screen goes dark, either ... it's already on but is locked up and thus won't charge or work properly. ... 15 minutes to make sure it gets enough charge, and then try turning it on again. ... If this tip (or anything else on my site) helps solve your Kindle Fire problem ...
Amazon.com: Customer Discussions: My Kindle won't charge
www.amazon.com/forum/kindle?_encoding...
Amazon.com, Inc.Jan 3, 2013 - If you can't see a Contact Us button on this page, then go to .... What canI do? I sent an e-mail to Amazon but have not heard anything. My Kindle is frozen and won't ...
Mar 31, 2014
How to unlock a Kindle. Lock won ...
Jan 27, 2014
Kindle paperwhite won't turn on
Nov 6, 2013
My kindle won't turn on....green ...
Dec 12, 2011
More results from www.amazon.com
1helpful
My kindle fire loses it's entire charge overnight when turned off. It occasionally makes a beep
Amazon.com: Customer Discussions: battery life on kindle fire hd
Amazon.com, Inc.Nov 12, 2012 - My son bought himself a kindle fire hd over the summer and we are having some issues with ... and unused yesterday from a full charge and it was < 5% (red battery) last night. ... a paperwhite kindle as its much lighter and I'm fed up losinghours to addictive .... ETA I tried again last night to power off and charge overnight. Kindle Fire HDX 8.9 battery ...
Dec 3, 2013
Kindle Fire HD won't charge?!
Apr 10, 2013
Kindle - Losing charge when ...
Oct 9, 2012
Kindle Fire HD Battery tips
Sep 17, 2012
1helpful
2answers
Why wont my kindle hd charge?
It could be the charger itself. Try taking the USB cable out of the charger and plug it into your computer, then plug in the Kindle. Your computer's USB port should be able to charge it. If it still doesn't charge, you might have a bigger issue with the tablet itself.
2answers
My kindle wont charge while I'm using it. It only charges when the kindle is off
You didn't specify the model of your Kindle, but the user guide for my Kindle states that it must be turned off to charge.
2answers
1helpful
2answers
Kindle not working. It will not turn on blank screen
Make sure that the kindle is fully charged. When charging the kindle 3 will have a yellow light indicating that it is charging. When this turns green, your kindle is fully charged. Make sure your kindle is fully charged and then try turning it back on.
Top Amazon Tablets & eReaders Experts
Grand Canyon Tech
Grand Canyon Tech
Jennifer Rock
Jennifer Rock
Are you an Amazon Tablet and eReader Expert? Answer questions, earn points and help others
