Question about Hino 2013 195
Hino euro 2 w04d... Overheating & skimmed head. After that my turbo doesnt work! What da???
I have Opel Astra 18ie it has a problem with overheating I have changed water pump ,radiator,skimmed the top and the engine block but still has overheating problem
i think since u have skimmed the head and the block u should check the tightness or tocks of the head bolts and retock if necessary
Mar 07, 2015 | Opel Astra Cars & Trucks
I have a t100 that keeps overheating we replaced everything from the water pump timing belt thermostat and it still overheating can you help me
Hi, did you recently skimmed the cyl-head? if so, then cyl-head is skimmed till last capacity, so you need to get the thicker cyl-head gskt. If not skimmed, remove cyl-head and skim it. it might be corroded or wapped.
Jul 20, 2014 | Cars & Trucks
Guys I've got a problem with a ford bantam 1.6i 2003 model rocam engine, its overheating even though the cylinder head was skim but it still overheating. please assist!
Check what head gasket was used . I suspect that an after market gasket was used. If that is the case there will be holes in the block and head thet have no matching holes in the gasket thereby causing the problem
Jan 07, 2013 | 2006 Ford Bantam 1.6i
HEAD GASKET SLOW OIL LEAK, HEAD WAS SKIMMED SINCE BEEN TOLD BY VW SHOULD NEVER BE SKIMMED GOLF 1.9DTI 2007 IS THIS RIGHT
if you had a oil leak that is not a reason for a head gasket or skimming the head. now the compression and voluum in the head has changed a lot. all it being a turbo wow :( sorry. those engine leak a lot of oil through the turbo seal
Nov 02, 2012 | Ford Expedition Cars & Trucks
Heyyy..... i bought a 2007 model ford ikon flair 1.3 rocam, 2 weeks ago. Now its giving me heating problem... i have to fill in water daily. Water vanishes very quickly in about 2 days... and the fan...
Sounds like a head gasket to me. if you go thru that much water in two days you should be seeing white smoke out the exhaust system.
Good luck
Nov 10, 2010 | Ford F Cars & Trucks
Still overheating after head is skimmed
waterpump? No movement of water/coolant, engine overheats. Engine overheats, warp heads. Next time you rip a head off, check gasket to see if head gasket failed or if there is a different cause to car overheating.
May 25, 2010 | 1999 Honda Civic
Loud diesel knock nissan terrano II head just replaced.
some black smoke comes out when i put foot down and loses power when goiong uphill i have a nissan mistral/terrano 2.7td
Nov 25, 2008 | 1999 Nissan Pathfinder
Hino 2013 195 Logo
121 people viewed this question
Top Hino Hardware & Accessories Experts
Steve Cox
Steve Cox
Jim Pate
Jim Pate
Are you a Hino Hardware and Accessory Expert? Answer questions, earn points and help others
