ck presser foot tension. even with sightest presser ft tension goods should feed. next ck that your feeder plate is not loose or broken. take off the plate and see if u can move the feeders with your finger. tighten screws makinf sure the needle is centered inthe feeder plate hole. if this is not the problen then youe=r feeder plate teeth are too low or worn out. look up how to raise the feeders. the should be 1/8" above plate.
Error Codes
Problem :
E000732 - 0001 Found cable from Machine to Reader becomes loose in reader housing due to Doc Feeder cable catching as the feeder is raised.
Sub-Assembly :Cause :Solution :
Replace cable (FH7 7167 000) dress Doc feeder cable away from plug by putting a twist in the doc cable before plugging into reader
where the document feeder attaches to the copier is small switch that sure pop up when the document feeder is raised and should depress when lower check it
Look in your owner's manual. I'm sure your machine has a reverse feed button but don't know if you can manually disable the feed teeth. If it is so equipped, it doesn't drop the teeth. Rather, it simply causes them to go straight up and down. If the teeth truly stay below the needle plate level, they are likely out of adjustment and need to bereadjusted and raised.
you didn't state model #, but raise your feeder up and look for the "skinny" piece of glass on left side of your large glass and make sure you clean it well.
first you need to set the selector to single feeds its located on the left portion of the printer then raise the paper feeder and slide the paper guide located on the right portion of the feeder, until you reach that mark on the feeder put single sheet on feeder be sure it fit on the left side then has a small gap on right, tnx
The lamp the is real bright below the document feeder under the big glass is gone. raise the doc feeder and make a copy there should be a very bright yellow/white light come on.
