I had same thing in the same Dell 1320c but in looking closer at the rollers there was a bit very small bit paper, so you still may have the same, it only just that little bit to stop it working , take out the front parts with the twisted plastic locks off and have a good look again, use a dry paint brush to clean in and under all the rollers, it worked for me, good luck.
SOURCE: False Paper Jam Error
Make sure the paper tray guides are set against the paper more likely to be the back guide not pushing the paper to the front of the tray. If you have the guides set correctly then place one sheet of paper in the tray and blot some methylated spirits on the leading edge along the page width and close the tray and try printing something.
You will have a jam repeat process 3 or 4 times then open tray and remove paper. Where you soaked the spirits into the paper there should be a grubby mark where the feed roller has rubbed and cleaned. Wipe the tray dry and put fresh paper in then hopefully you will now be able to print. If you cannot then the likely thing is that the paper feed pickup spindle is broken and will need replacing.
Hope this helps you and please rate me
Thanks J
SOURCE: Clear Paper Jam error -- but there is no paper jam!
I have the same problem. Answer? PUt the piece of junk in the trash and never, never buy brother products again. I called Brother and they had a refurb for more than what it cost me originally!!!!!
SOURCE: Paper is jam on the top feeder of Dell 1110
There is a section in the user guide that shows how to remove and avoid paper jams on this unit:
Click on the user guide link .
http://www.generalmanual.com/Printers/Dell-1110-Laser-Printer.htm
Printer paper jams can be caused from:
Paper that is sticking to-gether - fan your paper from both ends and both surfaces before placing it into the printer
Paper tends to absorb moisture in high humidity - this can also cause it to stick and jam.
Always store your paper flat - many printers jam readily when supplied with bent or slightly damaged paper.
There could be a piece of paper stuck in the printer from a previous jam - especially if you have printed labels - it only takes one tiny corner of a label to cause paper jams in any printer - cheap consumer models to commercial models costing thousands of dollars.
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
SOURCE: paper jam ,no paper jam found Dell 1815dn
give this a try
alternative :
Load
a piece of thick paper, for example photo paper and press the resume
button (may be diffrent button on diffrent models) a few times to the
printer picks up the paper and puts it through the machine.
SOURCE: 13.20.00 Jam in top cover area, no jam
pull your fuser out and you will find the jam and reason for the noise. it is pulled from the rear 2 covers and 2 screws
