Question about Nordic Track Exercise & Fitness
I have an Nordic track recumbent bike GX 4.0 Model No BB030G01381 The display console works fine but the backlight to it either flickers or just doesn't't come on Any ideas
6ya staff
SOURCE:
Anonymous
  • 64 Answers
SOURCE: Nordic Track Treadmill will not run
If console lights up but doesnt respond when buttons are pressed, you more than likely have a console problem. Key pad issue would be my best guess.
Posted on Jun 08, 2009
Anonymous
  • 95 Answers
SOURCE: Nordic track c2255 console displays FF and will
Hold down the speed up button and the stop button while inserting the operator key,if a bunch of numbers come up hit stop once, if nothing changed the console is bad.If the numbers change pull the key and reinsert it again, if nothing changes the console is bad.Also there usually is a tech sheet and test mode guide on the inside of the motor cover if you remove the screws and take the motor cover off you will see a white paper with lots of info.
Posted on Aug 01, 2009
SOURCE: Buttons doesn't work...
you more than likely need a new keypad
www.AtlantaFitnessRepair.com
Posted on Aug 24, 2009
Tim F
  • 103 Answers
SOURCE: Calibration Mode for nordic track treadmill model
Hello there, The calibration mode for a nordictrack is as follows.
With the safety key out, hold the stop and speed up arrow at the same time while inserting the key. Release the buttons. You will then be in diagnostics.
You then press the stop button one time.
If you are trying to calibrate the incline you just need to hit the incline up button and the machine will do an incline calibration. The unit should go all the way to the top and return to the bottom when completed.
If you need to calibrate the speed you will need to press and hold the speed up button on the console until the display reads 85. The machine should then be running at its maximum speed (either 10 or 12 mph depending on the unit)
The display will show a speed on the console and should be within .3 of the maximum speed.
If it is not then it will need to be adjusted using a potentiometer on the control pwb.
To access the control pwb open the hood cover. Should be 3 screws in the rear of the cover and 2 screws on the bottom of the unit.
Once inside the cover locate the control pwb. On the control pwb there will be a yellow/orange potentiometer. This is the adjusting part.
Use a non-metallic phillips head screw driver to adjust the potentiometer either clockwise for faster or counterclockwise for slower.
Hope this helps!
Good Luck! Tim
Posted on Jan 13, 2010
Testimonial: "Although I haven't attempted this solution, but it makes perfect sense and will attempt it as soon as I get back to the treadmill - Thank you"
Anonymous
  • 18 Answers
SOURCE: Nordic Track exp 2000I. Consol lights, buttons do not work.
If the console lights up but the buttons don't work, then unfortunately it's probably the console and they're not repairable that I know of. You may want to check the wiring harness and the connections at the console and at the controller under the motor hood. Pull them apart and check for bent pins. If they look good, the console is most likely bad.
Posted on Mar 10, 2010
Where to get user manual for schwinn 230
Do you mean the Schwinn 230 recumbent bike? Then Schwinn has the manual for two models (released in different years) on their product manuals page: http://www.schwinnfitness.com/schwinn_fitness_us/customerservice/manualsen.jsp . Expand the section on Recumbent Bikes and scroll through the list. The direct link to the owner's manual for the 2007 version is http://download.nautilus.com/supportdocs/OM/Schwinn/SCH_130-230_OM_RevB_web.pdf . The 2013 version is here: http://download.nautilus.com/supportdocs/AM_OM/Schwinn/SCH.230-Journey2.0.AM.OM.WARR.EN.pdf . The newer model has a USB port for a flash drive, among other differences.
I hope this helps.
Jan 20, 2016 | Nordic Track Nordictrack Apex 4100i...
Panel is flashing
Hi Ines, for more information about your question please visit the website below. Good luck and have a nice day.
http://c.shld.net/assets/own/spin_prod_670268901.pdf
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Sep 25, 2015 | Nordic Track NordicTrack GX 5.0 Pro...
Can't remove right pedal shield
The shield will not come off unless you remove the entire crank, not just the pedal. to do this, you need to buy a CRANK ARM PULLER TOOL available for around $15.oo at any bicycle shop. Make sure to get one for a square tapered bottom bracket. Just used one, the crank came right off and the shield simply lifted away. here is a link to a YouTube Video showing the tool and explaining the process: https://www.youtube.com/watch?v=N63ofGcRCYQ
Jan 28, 2014 | Nordic Track NordicTrack GX 5.0 Pro...
Nordictrack gx 5.0 pro will not turn on
Did you ever find a solution to the dashboard of your Nortictrack 5.0?
Jan 20, 2013 | Nordic Track NordicTrack GX 5.0 Pro...
Flashing Nordictrack R400 AudioRider Display
https://support.nordictrack.com/exercise-bike-support/
Apr 05, 2017 | Nordic Track NordicTrack GX 5.0 Pro...
Nordic Track Ifit Treadmill has power but walking pad not working
If everything on the display console is working correctly then we know it is either a problem with the wires from the console to the controller or the controller itself. In most cases this means you need a new controller. To verify, take off the motor hood and find the green circuit board called the motor controller. With the power on go into manual mode and push the speed up button to a slow speed. If you see an LED light with "spd ctrl" next to it flickering but the belt still does not move then we know the problem is with the controller sending the signal to the walking belt, in which you should check the wires that go to the motor. If they are connected correctly then we know a new controller is in order. If you do not see a flickering light then it means the speed signal never got there and the problem will be with the wires going from the console to the controller. This is called an upright wire harness.
Apr 18, 2009 | Nordic Track NordicTrack Treadmill, A2550
Exercise & Fitness Logo
99 people viewed this question
Top Nordic Track Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Treadmill Repairs...
Android Man
Android Man
Are you a Nordic Track Exercise and Fitnes Expert? Answer questions, earn points and help others
