I have the same situation. I use my Playstation or any DVD or BluRay player with the built in apps(almost all for last 5+ Years do). So it’s still on the TV, and if you buy one compatible with your equipment which usually means the same brand that you’re tv is, you can probably use the same remote. Good Luck, just pick up a cheap dvd or blu Ray player, a PlayStation 2/3/4 or Xbox/Xbox360/XboxOne works great too, or plug your phone directly into the TV and get a long cord to control it from the couch. Best Wishes
SOURCE: the Netflix app on my
I had the same problem with my Vizio XVT473SV. I couldn't find the Netflix Activation Code. When I clicked on the Netflix App, the TV would ask me if I wanted to connect to Netflix, then it would ask me if I was a Netflix member. After clicking yes to both, it would tell me it couldn't connect to the Netflix server, check with Netflix.com/tvhelp. After a couple hours of troubleshooting, the solution was......your first use of the Netflix App has to be via the Ethernet Port/Cable. This will give you a screen with the Activation Code, after you activate the code in your Netflix account, you can go back to using WiFi on your Vizio TV to connect to Netflix. Step by step instructions are...
1) Exit the Vizio Netflix App.
2) Physically connect an Ethernet cable to your broadband (just temporarily)
3) Check to make sure the Vizio is using the Ethernet port and not your WiFi (Apps Button - HDTV Settings - Network...may have to reboot the TV to get Ethernet port connection)
4) Start the Vizio Netflix App
5) Click OK to start the Netflix App
6) You should now see a different screen that gives you the Netflix Activation Code.
7) On your Computer, Login in to Netflix,
8) Click on "Your Account & Help" link on upper right corner
9) Scroll down to Watching Instantly on your TV or Computer section
10) Click on Activate a Netflix Ready Device
11) Enter the Activation Code shown on your Vizio TV and click Activate
12) Once your Netflix account (on your computer) shows it is active, your Vizio TV will automatically log in. You should see your Instant Queue.
13) Exit the Netflix App, unplug the Ethernet cable, Turn Off your Vizio TV.
14) After 20 seconds or so (remember the TV is software driven), turn the TV back on and your WiFi should connect again.
15) Use your Netflix App and this time it should automatically connect via WiFi
note: just make sure that your wireless DSL/Cable Modem or Wireless Router is not blocking your WiFi connection request from the Vizio. You can check the connection status in the modem/router or in the Vizio in the HDTV Settings - Network.
SOURCE: Just purchased a Vizio 37" HDTV with Netflix app
The Vizio does not have Internet capabilities. You need to hook up a computer via the VGA or HDMI port. Then youor computer controls what you do with the intenet.
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
SOURCE: the tv goes on but the apps display with netflix,
Try restetting the TV by unplugging for 2 minutes then retrying it. If it still fails then there is most likely a failure on the main board in the TV
SOURCE: No Facebook app on optica smart tv
What is the exact model number to your TV? Look for this detail, at its back cover. Gopakumar Gopalan Google
Testimonial: "Model no 7042. That's all it says. Sku is t844 not sure what that is thought I'd put it on here incase any good. Have you an idea what to do?"
SOURCE: Visio smart tv apps
You have to jailbreak it and if it's android I can install the app store
Hi Marcin Machalek, I want to help you with your question, but I need more information from you. Can you please add details in the comment box? What is the manufacturer name and model number?
