Boating Logo
R
Roger Levesque Posted on Jan 07, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Yamaha 1997 8 hp 2 stroke outboard. Need timing, carb, throttle settings
Richard Doherty
Level 2:
Habit-Forming:
New Friend:
  • Expert 53 Answers
  • Posted on Mar 06, 2019
Richard Doherty
Expert
Level 2:
Habit-Forming:
New Friend:
Answers
53
Questions
0
Helped
19497
Points
120
Whats the serial number
5 Related Answers
Anonymous
  • 710 Answers
  • Posted on Apr 27, 2009
SOURCE: 40hp 1987 yamaha outboard motor will run for 30-60
Sound like the fuel pump is not keeping up with the engine's demand. Check it out. Good luck. Hope this helps.
Anonymous
  • 18 Answers
  • Posted on Sep 21, 2009
SOURCE: yamaha outboard starting
New plugs and service
chris
  • 232 Answers
  • Posted on Sep 29, 2009
SOURCE: l50deto 2 stroke outboard stalling at high revs
fuel pump could be the cause but also the float in the carby could be not set at the right level and starve the motor at high revs .
Testimonial: "I found the solution, carbs werent clean enough. Got a compressor in there and solved it. Thanks anyway"
Anonymous
  • 86 Answers
  • Posted on Oct 16, 2009
SOURCE: Spark plug gap 150 hp Yamaha outboard
The correct gap is .035
espressonist
espressonist
  • 1711 Answers
  • Posted on Oct 03, 2010
SOURCE: i have a yamaha 2
On the tachometer back you have secured a wire thread just like the one from the brakes of a bicycle. The other end of the wire is secure to the engine. This wire complete, need to be replaced.
As a test first disconnect it from the tachometer and see if ok if not then the problem is with tachometer.
What is the float setting for an '04 150 Yamaha 2 stroke
Every 2 stroke I've ever worked on, the float is set parallel to the bottom of the carburetor. Turn the carb upside down and look to see if the float is even with the bottom of the carb.
Yamaha 2 stroke 15 hp outboard won't start. Hasn't been used in several years. Using new gas. leaking gas, will turn over, but won't start
Hey Janine,
The carb(s) is/are stopped up.. they need a complete cleaning and setting... Any qualified professional can handle this job,, - Even a professional two-cycle motorcycle mechanic can do this job)
1helpful
Yamaha 40 outboard stuck at full throttle won't idle
Sounds like accelerator butterflies are stuck,you probably need a good mechanic to sort this one out.try operate accelerator linkage on carburettors by hand but do not force, take off black air cleaner and spray penetrating oil onto butterfly shafts
Yamaha 250vx cards outboard lost rpm wont go above 4200 rpm
clean and balance carbs , compressions all above 100psi ? sparks on all cyls ?
How do i set timing on a 1996 mariner 40 hp 4 cylinder 2 stroke outboard?
timing marks on flywheel and a pointer above the carbs , under the flywheel there is an adjustable rod from the trigger to the throttle linkage ! strobe light required , cant remember timing off top of my head as out so google it !
30 hp 4 stroke carburator problem
Check your "sync n link" of the throttle pick up and the ignition timing.
1helpful
Top Yamaha Boating Experts
neil
Stan Ford
Are you a Yamaha Boating Expert? Answer questions, earn points and help others
