The "rm ed007" remote that you mentioned is most likely a universal remote control, which can be programmed to control multiple devices, including your Sony DVD player and Sony Bravia TV.
To program the remote to control your Sony DVD player, you can follow these steps:
Turn on your Sony DVD player.
Locate the code for your Sony DVD player in the code list provided with the universal remote.
Press and hold the "Code Search" or "Setup" button on the universal remote until the indicator light turns on.
Enter the code for your Sony DVD player using the number buttons on the remote.
Test the buttons on the remote to make sure that they are controlling the Sony DVD player as expected.
To program the remote to control your Sony Bravia TV, you can follow these steps:
Turn on your Sony Bravia TV.
Locate the code for your Sony Bravia TV in the code list provided with the universal remote.
Enter the code for your Sony Bravia TV using the number buttons on the remote.
Test the buttons on the remote to make sure that they are controlling the Sony Bravia TV as expected.
Does the remote have a TV setting? In other words, is there a setting on the remote where you can go back and forth between TV, DVD, Cable, etc? If not, you cannot use it for that purpose. If it does, try setting up your remote with one of the following codes.
It may or may not work. There's no way to program it unless it's a universal remote, and even then you'd need to find the codes. I'd put some batteries in and hit power... if it works it works.
Universal remotes aren't expensive though. Pick one up if the old Sony won't work.
It sounds like you may not be on the correct input selection on the tv to watch the dvd player. Ther are probably three or four inputs to choose from on your tv. whichever input you hooked the dvd player into on the tv is the same imput you have select using the tv's remote control in order to watch movies on the dvd player.
the default for the rh7823w remote is to operate lg tvs. Popping out the batteries should reset the default. my manual saysto select a different tv hold down the tv power button, press the number buttons for the manufacturer code then release power button.
if you have a universal remote try their website, you can also try hitting the power button on the remote severl times(maybe hundred) intil your tv turns on, then hit the enter button, this will program the tv...
