SOURCE: no water or rotation to upper rack
is there enough water in it.water should be about 1/2 below heater.if it is and you can hear the motor running then the chopper can be broken and food is blocking water passage to top spray arms.
SOURCE: Whirlpool GU3200XTP dishwasher - No spray on upper rack
Sounds like the hose assembly that attaches to the rear of the upper rack has come undone. just pull out the upper rack and reconnect it.
please rate my answer as a fixya! thanks.
SOURCE: Dishwasher Not washiig properly suspect upper spray arm is
the most common problem is low water pressure.when you start the dishwasher check the amonut of water in the bottom of the dishwasher there should be about an inch of water in the bottom.
if needed add some more water to the unit and see what happens this can determine if the fill valve is bad,or the control board.if the unit washes change the fill valve or check your water pressure,if there is no change then the main wash motor needs to be change because it is not putting enough water through the system to properly wash.
SOURCE: The upper arm is not rotating
Take it apart and clean it, water pressure should spin it around, there are bits of food/rice plugging it and stoping it from rotating.
SOURCE: The upper dishes are not getting cleaned. I ran
I have an older dishwasher also and recently mywife also complained about it not cleaning right... so me being the man I amtried in vain to clean the things... Bought new spray arms online and installedthem in minutes...now the thing works like new... However I have also foundthat if the heating element goes bad then that also can mess things up bad...So I would buy new spray arms, and also check out the heating element to makesure it is working... Here is a tip that will help you with the onlinebuying...
Dishwasher SprayArms not Spinning
How to Buy ApplianceParts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The HeatingElement not Working
DishwasherMaintenance
DishwasherResidue and Film on Dishes
heatman101
Asker's Testimonial "explanation very clear. will give it a go and see howsimple it was. thanks Ronnie " - ronnieshomes
