Press and hold the Home button. Siri is enabled by default on all devices that support it, so usually you can just press and hold the Home button to start the Siri interface. The Siri prompt will appear, and you'll be able to speak your command or question.[1]
Say "Hey Siri" if your iOS device is plugged into a power outlet. When your iOs device is plugged in, you can say "Hey Siri" to launch the Siri interface without pushing any buttons.
Ensure your iOS device is compatible. Siri does not work on older iOS devices. The iPhone 3GS, iPhone 4, iPad, iPad 2, and the iPod Touch 1st-4th generation do not support Siri. Even though these devices may be able to install a version of iOS that supports Siri, they won't be able to use it.
I hope this response helps you out.
I wish you the very best of luck! If I can help you further, please let me know.
I'm available for longer billable discussions at https://www.6ya.com/jim_8a00509cb5f5d7e2
If I've assisted you, I'd greatly appreciate you taking the time to provide me with a favorable rating. Thanks so much!
