Cameras Logo
F
Frederick Posted on Jan 06, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I get Mem Card Parameter Error on New 64GB SD Card and Mem Card Error on older 4GB SD Card previously used successfully in Lumix DMC TZ3 Camera. Could it be the camera?
Phil Whisenant
Level 2:
Habit-Forming:
Cheetah:
An expert who has answered 20 or more questions within one hour.
  • Expert 163 Answers
  • Posted on Jan 06, 2019
Phil Whisenant
Expert
Level 2:
Habit-Forming:
Cheetah:
Answers
163
Questions
14
Helped
46104
Points
361
It most certainly could be the camera miss reading the card. However, lately many of the sd cards I have purchased can't be formatted. If you have a PC/Laptop you can re-format the card and then try it in the camera.
2helpful
What is the maximum size to use for an sd card for lumix dmc tz3
The maximum size SD card you can use is 2GB because that is the maximum size SD card you can buy. Cards bigger than that are SDHC (Secure Digital High Capacity) cards. Fortunately the TZ3 is capable of using SDHC cards of 4GB and larger.
13helpful
3answers
Message: Memory Card Error - Memory Card Parameter Error on 4gb SDHC card
you may try some card recovery software, recommended asoftech photo recovery that helped me before.
http://www.asoftech.com/apr/
If needed, you may do a quick format of the card, and then use asoftech photo recovery to recover files.
2answers
Not able to 'delete' a picture from my Lumix TZ3
Sounds like a MobileMate quirk Tanya. Use your USB cable connection to your PC/Camera interface and delete pics that way too see if this funny goes away.
If it does, and I believe it will, then it is a SanDisk issue not revising the File Allocation Table(FAT) after deleting the Pic File on the mem card.
You could also find out if this is just an SDHC SD card reader issue by using an older less dense standard 1 or 2Meg non-SDHC mem card in the reader and see if issue goes away.
The fallback of course to view and delete the pics on the camera before download, or download pics then note which pic file numbers you want deleted after viewing on PC, then put SD card back in camera and delete them there.
Another option for trial, is to cut and paste the whole DCIM folder, or sub pic folder to your PC from off the SD card using the card reader. The camera automatically generates subfolders under the DCIM folder if you completely remove(deleting by a cut or move), when you take your first picture on a camera with a DCIM but not sub pic folder. Try this first and I think you will find all pics will be deleted from camera that are in a subfolder under DCIM. If not, then cut or move the whole DCIM folder and create a new DCIM(empty) folder on the SD card using the PC and card reader. Of course using this method you cannot selective delete individual pics from the mem card. You would be deleting them all after the Folder cut or move from the SD card.
1helpful
Lumix DMC-TZ3
Memory card likely has temporary(needs formatting) or permanent problems(needs replacing, common for off branded china junk).
First format the mem card on your camera by pressing center Menu button then scrolling down to the end of the menu to Format. If this does not work, and you have bought a Name Brand SD card; Sandisk/Kingston/Patriot etc, return it to place of purchase with receipt, or creditcard use to purchase it, and they will replace it.
Hi - You will need to get an SDHC reader and then try the following procedure.
You can either plug in you camera to the PC as it should appear as a “Removable Drive” or put the card in a card reader attached to your PC.
Next, if you are comfortable with using a PC then you can download a FREE utility that will recover your photos from the following link:
http://www.cgsecurity.org/wiki/PhotoRec
If you need something a little more "user friendly" then you will need to buy the software. If you search the web for photo recovery software you will find many.
One I have used successfully is RescuePro that used to be bundled with some Sandisk products. Now you can get it from the link below:
http://www.lc-tech.com/software/prwindetail.html
You can try the demo to see what you can recover before buying.
Remember - Do NOT try & write anything back to the card until you can recover your pictures to your PC safely!
Please take a moment to rate this solution & let us know if the information given was useful to you – Good Luck!
Informatica
Panasonic fz 18
i suggest you first try another card to check if the card or the camera is faulty. if it is the canera then it could be the sd card slot that is faulty. this will have to be checked by a qualified panasonic tech.
5helpful
4answers
I have been rummaging around trying to find two solutions: 1) to get my Toshiba Satellite card reader to read SDHC cards and 2) to get my desktop USB ports to read SDHC cards. While MS offers a hotfix for XP, it does not always work because of the different Chip Sets in computers. I have also read where posters say that the SDHC card works in the compter NOW, but NOW will not work in the camera... and the SDHC card NOW works in the camera but will NOT work in the computer.... I found a tekkie article that may help clear the air... SDHC cards are formatted in Fat32x (NOTICE the "x") and SD cards are formatted in Fat32 (no 'x') and these compatibility problems arise when the user unwittingly or unknowingly RE-formats the SDHC card, either when it is put in the computer and won't read or when it is put in the camera and won't read... but just don't bother to mention that THAT is what they did upon inserting the card and only proceeded to complain about an apparent incompatibility. The camera or computer might even mislead you asking if you want to format the card..... but all is not lost. The Panasonic site gives a program AND a pdf instruction book on How To ReFormat an SD or SDHC card specifying the proper Fat32x or Fat32 format. Hope this helps.
2answers
Retrieving file
There are companies that claim to be able to retrieve deleted files on mem cards, if their space has not been written over by other pics taken sense, or a mem card FORMAT. Google it.
Your better approach may be to try to recover the files showing 3Meg size on your computer download. Sounds like mem card quit working correctly after first 100 photoes. Was this a name brand SD card like San Disk or Panasonic? Beware of off brand junk sold on ebay or other sites CHEAP. They are designed to report back the size they claim to be, but are 1/2 size capacity or less in reality. You never know until you need your photos. The other thing is SD cards fail and are never a good as a BackUp source for files. For file xfers only in general.
Good lesson for all is to be sure all your pics show up on your computer before deleting on camera.
1helpful
6answers
I recently bought a DMC-TZ3 and have been researching memory cards. Several sites sell cards with the camera and list the card type. I would suggest buying one of these cards. Any cards larger than 2gb must be SDHC type SD cards. There appear to different types of SDHC cards, 1.0, 1.1 and 2.0. Check out Wikipedia.org for a description. 2.0 cards are not compatable for devices developed prior to 2.0 so that may be the reason for the camera problem. So far I haven't seen anything that states what type SDHC card the camera requires. I found a computer memory site that that sells memory that they say will work. There may be others.
http://www.mymemory.co.uk/compatible-memory/Digital_Cameras/Panasonic/Panasonic_Lumix_DMC-TZ3
Top Lumix Cameras Experts
Ngoro
SmartAviator
SmartAviator
Are you a Lumix Camera Expert? Answer questions, earn points and help others
