SOURCE: agitator very noisy while washing
There is a small roller that tightens the drive belt for the drum inside this unit. If it is loose it makes a squeaking noise. Tightening this may solve your problem. You will have to take off the back panel to do this repair
SOURCE: kenmore series 80 washer makes loud knocking noise during spin cy
Unless your front loader is set firmly on concrete
and leveled to perfection, the force of a heavy wash load spinning in
excess of 1000rpm will create a bit of vibration and noise.A firm footing is your best defense against to much movement.
Also due to the earlier movements during the spin cycle, the
shocks that are used to dampen the spin cycle might have been broken or
damaged.
If the problem persists inspite of proper levelling, please do check for the shocks or might have them replaced them for good.
SOURCE: my kenmore 417.42042100 model front
Here's what the problem is.
http://www.youtube.com/watch?v=UwpKP_9_fAA&feature=player_embedded
It's been designed to fail so that you buy an expensive part.
SOURCE: Kenmore washer (model # 110 24872300) won't agitate.
Your machine has no belt. It has a direct drive coupling. The direct drive coupling between the motor and transmission must be replaced.
SOURCE: Buying a used Kenmore stackable washer/dryer
stackables are convenient..small but work great.....youll find what you need at lowes or home depot
