Do I just need to replace the switch membrane?
Yes, depending on your model, your solution can probably be found here:
http://www.microwavecontrol.com/samsung_se_error.htm
"SE" error means you have a failed membrane keypad.
The best way to solve the problem is to replace the control panel frame, which
comes with a new keypad installed.
It is part number DE94-01647A available from
The Pros here
for $39.01 plus shipping.
Here is a video showing how to remove a typical over the range control panel assembly in under 5 minutes.
If you have any trouble getting the grille off once the screws are removed, slide the hood vent grille to the left about 1/4", then then pull it forward. On some models there are L-shaped clips that fit into a slot to hold bottom of the vent.
Next, disconnect the keypad strip as shown in the photo below, then remove the screws that hold your circuit board in the old frame.
Then carefully (since the display is made of glass) move your circuit board to the new frame, and reassembly is the reverse of disassembly.
try this # 866-243-6498 its samsungs distributor for mini splits but they might be able to get you where you need to be.
