SOURCE: Need wiring diagram
here would be the hook ups that are needed. at the air handler
r-red
g-green
c-common
w1/w2/aux-white (DEPENDS ON WHAT TYPE OF SYSTEM YOIU HAVE)
then these are what goes to the outside unit
y-ylw
o- org/or b-blue
c-white
r-red
personally contact me if yopu still have questions. thanks
SOURCE: I need the wiring diagram of pump it has 5 pins coming out of pump
hello, i holding a wiring diagram central locking system,model 201,it have a 6 pin,
hoping it"s help to solve your problem,ty
SOURCE: need a wiring diagram for a 88 ford bronco fuel pump
hi you can try this site they might be able to help you....hope that helps
http://images.google.co.uk/imgres?imgurl=http://www.supermotors.net/getfile/72398/fullsize/tod.jpg%2520alt%3D&imgrefurl=http://www.supermotors.net/clubs/superford/registry/2742/12671-3&usg=__m_cAI85EgFEzDfBx-ag0LCqZLc0=&h=434&w=565&sz=57&hl=en&start=20&itbs=1&tbnid=wOnVrpIcnPoaoM:&tbnh=103&tbnw=134&prev=/images%3Fq%3Dford%2Btempo%2Btransmission%2Bbox%2Bdiagram%26hl%3Den%26sa%3DG%26gbv%3D2%26tbs%3Disch:1
SOURCE: I need a wiring diagram
You cannot wire a three phase motor for single phase and you cannot wire a single phase motor for three phase. If you have a three phase dual voltage motor your options are 220 or 440 volts. If you have a single phase dual voltage motor your options are 120 or 240 volts. A 208 volt Hobart motor will only function correctly on 208 volts and is not dual voltage.
SOURCE: I have a dayton 3phase motor that i would like to
A 3 phase motor will not work on a single phase supply so I'm sorry but a wiring diagram will not help you.
