SOURCE: 1 HP 3 Gallon Air Compressor does not build up pressure.
it sounds like the regulator is out of whack turning down increases air pressure. make sure there is no leaks
SOURCE: porter cable 3hp air compressor
Check to see if the switch will kick in if the pressure is released from the hose going to activate it...if so then the problem is the air being trapped between a check valve and the switch in the hose...
I think that is your problem...
There should be a way for the air pressure to change and represent the tank air pressure accurately....
The different compressors all have different ways of checking the air and then allowing it to release as the the tank pressure decreases..
There is a small hole there somewhere that is clogged with dirt and or oil...find that and clean it and you are in business again...
heatman101
Possible that there is leak on the system or the piston/rings/cylinder has worn out.Also check for oil within the unit. Check the compression of the cycle and if this is too low it means that there is wear and tear and will require a overhauling and reset.
