SOURCE: Washer will not run Kenmore 90 Series 2872 Top Load
Do you hear a distinctive "click" when you close the lid? If you don't, the lid switch is probably bad. You can by-pass the switch by lifting the console and unplugging the switch connector. If you jumper across the black and white wires in the connector plug, this could prove whether or not the switch is defective. If you jumper the switch, or if the lid switch proves good, and you still have no activity from the drive motor, I would check the start capacitor, and/or connections to the motor before I would suspect a timer problem (still a possibility, though). You should also check your line voltage coming in just to make sure you're getting power to the unit (not trying to insult your intelligence). There should be a wiring diagram located under the console to aid in troubleshooting. When taking readings on 120 VAC connect one lead to your neutral and take readings with the other lead. This way you have one hand free, and the readings will be more accurate. Ground is not always reliable. Let me know what you find and if I can be of more assistance.
SOURCE: Vibration problem with Frigidaire front load washer.
Can't tell you about your particular model, just some generalities:
Unless the shock actually failed from a defect, you might have broken or damaged something else. Check especially for wires or other parts pinched between the tub and other parts or the housing. Also, make sure the tub shaft hasn't broken or worn the seal at the rear or the seal at the front. If this unit has ballasts one of them may have broken or broken loose to cause the shock to break. I had one similar with that problem. Might want to take the ballasts off the tub or brace it to keep from stressing the bearing and seals. Mine had three ballasts, one large cast iron one on top of the tub and two concrete ones either side. One of the concrete ballasts broke and the tub vibrated and pinched wires and damaged seals and was totaled. If nothing but the shock is broke, it's probably worth repairing. However, the other shocks also have the same amount of wear, check them carefully first. Also, check the seals while you're in there. Use a digital camera and take pictures of everything before you take it apart and be very careful with wire routing. Most parts are held with (probably) metric and Phillips. Always unplug it to work on it and plug it into a ground-fault protected circuit. Best to set the machine up to run then plug it in remotely if possible.
SOURCE: I need to replace the coupler on my direct drive whirlpool washer
the easy way to get to it is that there are 2 Philips screws on the front or the back of the head take those out flip the head back you will see 2 brass clips stick screwdriver in the front and pop the clips and unclip the lid switch. than grab the lid of the washer and tip it forward. than if you look down you will see the pump take the 2 clips off of the pump and do the same for the motor that is where the drive coupler is located. you will need a 3/4 socket with extension to tap the drive coupler into place then repeat steps to put back together
SOURCE: washer wobbles
Its the clutch and its causing the drum to spin unbalanced It will need replaceing and a new sealed bearing too
Please rate our help to keep the free service online ++++
SOURCE: Direct drive-type Kenmore washer will not spin.
Check the video at the following link. I think you will find it helpful. Hope so and best wishes.
http://www.youtube.com/watch?v=WLPGs2UMUJc
