Question about RCA Audio Players & Recorders
I love this little radio, but the origina telescoping antenna is gone. There are antennas for sale on Amazon, but I'm not sure what kind to buy. The major difference in replacement antennas seem to be the end that fits into the opening on the top of the radio.
There are 4 things you need to look at for the replacement, the two most important details are how the antenna is attached inside the radio, and the second is the outside diameter of the antenna. The other two details are the collapsed length and extended length. You will need to open the radio to see what attachment method is used, usually a small screw through a hole through the base at the end of the antenna. There will also be a wire attached with the screw (usually), that connects to antenna to the radio circuits. Carefully remove the broken antenna from the radio, then you can note the attachment method, and measure the outside diameter, and the collapsed length.
Posted on Dec 31, 2018
SOURCE: need telescoping antenna for Bearcat BC350A scanner
http://www.scannerworld.com/content/product/category/Antennas
hope this helps.....Good Luck!
Posted on Dec 15, 2008
SOURCE: insignia digital tv converter/indoor antenna no signal
I had the same problem but realized that when it said NO SIGNAL,,,,it just ment for that station,,,,,switch channels and they will start to come in,,,
Good Luck,
charh20
Posted on Feb 22, 2009
SOURCE: yamaha htr 5240 receiver, need fm antenna adapter
this is your manual http://www2.yamaha.co.jp/manual/pdf/av/english/re/HTR-5230.pdf
this is the 300 ohm adapter you need from radio shack and just install some small gauge speaker wire to it. or just splice the one that came with your receiver.
http://www.radioshack.com/product/index.jsp?productId=2062054
Posted on Feb 27, 2009
SOURCE: 1999 Mercedes CLK radio antenna
look at antenna wires make sure every thing is in contact.if all is good.sound like problems in the sound amplifier.in radio.
Posted on May 07, 2009
Feb 26, 2018 | Pioneer Audio Players & Recorders
Nov 24, 2017 | Audio Players & Recorders
Jun 29, 2015 | Motorola Radio Communications
Jul 22, 2014 | Sony Boombox Am Fm Tv Weather Band...
May 11, 2014 | Durabrand DUR7 Portable DVD Player
Aug 29, 2013 | Sony CFD-S05 Radio Boombox
Apr 05, 2010 | WeatherOne W731 Radio
Feb 25, 2010 | Citizen ST-555 2.2 in. Television
Mar 30, 2009 | Panasonic DMR-EZ47V DVD Recorder/VCR
Dec 02, 2007 | Jwin (JX-CD512D) Sports Portable CD Player...
Nov 06, 2019 | RCA Audio Players & Recorders
47 people viewed this question
