SOURCE: how to deactivate call barring?
Go to Settings >>> Network services → Call barring. Clear all the call barrings that you have set.
Hope this helps
SOURCE: I have a Micromax X414 mobile, I locked the
Hai friend, in this case you can talt to your customer care and ask them for password.
SOURCE: how can i deactivated the incoming barring of my
Have you tried typing "stop" and then enter that?
SOURCE: how to deactive incoming call barring problem for
Contact/call to customer care is the best solution.Good luck
SOURCE: my mtn sim card barring is blocked
There is no such barring code, this security code (number) is maintain by the Sim Card service provider.So, if you want to block contact/call to your sim card provider/customer care.Good luck.Thanks for visiting fixya
You can bar the calls that can be made
or received with the device (network
Make calls 35
© 2010 Nokia. All rights reserved.
service). To modify the settings, you
need the barring password from your
service provider. Call barring affects all
call types.
Select from the following voice call
barring settings:
Outgoing calls - Prevent making
voice calls with your device.
Incoming calls - Prevent incoming
calls.
International calls - Prevent calling
to foreign countries or regions.
Incoming calls when roaming
- Prevent incoming calls when outside
your home country.
International calls except to home
country - Prevent calls to foreign
countries or regions, but allow calls to
your home country.
To check the status of voice call barrings,
select the barring option and
Options > Check status.
To deactivate all voice call barrings,
select a barring option and Options >
Deactivate all barrings.
To change the password used for
barring voice, fax, and data calls, select
Options > Edit barring password.
Enter the current code, then the new
code twice. The barring password must
be four digits long. For details, contact
your service provider.
hope this helps
John
