SOURCE: Campbell Hausfeld Air Compressor auto shut off switch not working
i have the same one and mine was broken by my kids , i had to replace the entire component, DONT RUN COMPRESSOR with out the regulator working IT CAN EXPLODE IF OVERFILLED,a must fix situation i believe i got mine from sears , a great unit ive used it painting and with many air tools over many years now , well worth fixing mine is a little loud but dependable good luck.
SOURCE: help! air compressor trouble.
ASSUMING YOU ARE TALKING ABOUT THE PRESSURE SWITCH. YOU SHOULD EITHER HAVE 2 WIRES OR 4 WIRES ON THE SWITCH. THE SWITCH IS TYPICALLY MARKED LINE-LINE-LOAD-LOAD. IF YOU CAN SEE THE INSIDE OF THE SWITCH YOU WILL SEE THE CONTACT POINTS. ONE CORD WIRE CONNECTS AND PASSES THRU ONE SET OF POINTS TO ONE WIRE OF THE MOTOR. THE OTHER CORD WIRE PASSES THRU THE OTHER SET OF POINTS AND CONNECTS TO OTHER MOTOR WIRE. YOU TYPICALLY WILL NOT HURT THE COMPRESSOR BY HAVING THIS WIRING INCORRECT - PROBABLY JUST POP THE BREAKER INSTANTLY. IF YOU CANT SEE THE PATH THRU THE POINTS YOU CAN OHM THRU THE POINTS AND GET A CONTINUITY BEEP ON A VOLTMETER. IF THATS NOT AN OPTION, JUST SWITCH THEM AROUND UNTIL IT RUNS. HOPE YOU BOUGHT THE SAME CUT-IN AND CUT-OUT PSI. GOOD LUCK AND WRITE BACK IF THIS DOESNT GET IT. JODY
SOURCE: Campbell Hausfeld Air Compressor won't start
The compressor starting problem is common to most of the small portable compressors. Poor design and undersized components are to blame. If you have one of these units i suggest looking into a product called the Smart Start by Conrader Valves. It is interchangeable with the standard air filters and allows the compressor to start without fail. check it out- www.conrader.com.
SOURCE: Campbell Hausfeld extreme duty 4 gallon air
check for a crimped or damaged line going to the presure switch or it might b the presure switch itself
