SOURCE: alba spkrkit559
Raymond,
I have the same Surround sound system and a virgin media box. Mine has been disconneted for some time and I am just trying to figure out how to hook it up again. To be honest the manual that comes with it (or maybe just mine) is useless. The diagrams don't actually show the correct DVD player or connections. I suppose though it's better than having no instructions at all. If you post your E-mail address I can scan it for you. I am not sure if you can connect everything you have but I managed to connect the Vigin Media box and DVD to the kit and it worked fine (it might be possible to put a scart switch somewhere).
SOURCE: akai lct3201 ad power supply
Hi doonz75
I got same problem with MLT169A power supply it wont power on. but i found service tech who fixed my power supply. but he stays in toronto, canada. only thing is you have to pull power supply out and mail it to him. his email is [email protected]
SOURCE: Replacing the Y-MAIN or Y-SUSTAIN Board in Philips 42PF9630A/#&
I called PTS 1-800-844-7871 they told me it was an easy fix. The part is $162.75. Im gonna try it.
SOURCE: how many Main Boards are in the Philips 50
the Philips 50'' Plasma TV model 50pfp5332D/37
has only one main board
has many sub bords supporting tat main board
SOURCE: philips tv powered off and wont turn back on
There is a smt located at 7404 [C-6 Bottom] A common problem, does the tv make a sound like it wants to come on? Location 3239 should be small resistor, 3414 another resistor and a driver transformer at 5402 if it looks burned. See MCM electronics website and see if there is a kit to repair this. Or ask for part #s as per location of problem area mentioned. What you will be doing is changing the timing so all the components will come on at the same time. If this is done correctly you will notice the top of tv screen will flash red, green and blue lines. This will be the new norm each time you turn it on. But it will be OK. This is what the flashing green light is telling you. signed the Green Lantern7!!!!!!!
