SOURCE: 59 C0 error on hp color laserjet 5550
59.C0error on hp color laserjet 5550 dtn
can you please suggest a solution for the above error on my printer urgenty
the printer is sensing that one of the motors are not turning.remove the cover from the left side .you will find the main drive motor,next to the motor you will find a sensor clean this sensor with some electronic board cleaner .be sure that the sensor it dry before turning the printer on.
SOURCE: LaserJet 3600n Printer: how can i fix 59.C0 printer error hp lj 3600...
i have many times working on this printer and i always experience this problem...i think this problem is disalignment of the main gear...check the gear if its on the alignment and its work for me and the problem never comes back
SOURCE: hi, i have problem with
59.XY A printer motor error has occurred.
(X=C=developing disengaging motor rotation error)
(Y=0=no color/black)
Developing disengaging motor error
1. Reconnect the connectors J16 for the developing disengaging motor and J1100 for the DC controller PCB.
2. Replace the developing disengaging drive assembly.
3. Replace the DC controller PCB. Calibrate the printer after replacing the DC controller.
