SOURCE: hi Am having kyocera 4050
Here is what an 1102 error is and what some of the things to look for are.. hope it helps..
1102 SMB(SMB)
Error: User/Password or SharedName/FolderNameDomain name not entered as Domain UserInput
User Name with one of the form "Domain\User", "Domain/User", "User@Domain"SMB)
User Name/Password or Shared Name/Folder Name ErrorSpecify invalid User/Password (includes unspecified)Input correct User Name/PasswordSpecify the User who is not permitted for accessing to the folderInput correct User and Password
Check access limit for send destination folderSpecify invalid Shared NameInput correct Shared Name
(See the reference for the symbol which is possible to use for Shared Name)Host Name ErrorCheck if any prohibited letter (see the reference) for Host Name is included or notSCAN TO EMAIL(SCAN TO EMAIL)
User Name/Password ErrorUser ID for Authentication is not entered/entered wrong User ID
Wrong Password for Authentication is enteredInput User ID/Password which is used for Authentication from [Advanced] on Command Center correctly
([Login User Name] on [POP3] page or [SMTP] page)
It's actually related with SMB.
The shared folder on the server may be blocked by an open ghost connection.
A restart of the samba service may repair
In case of a problem or clarification or my solution was insufficient, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
SOURCE: Kyocera km 4050 showing error code cfb31 how to clear it
hello,
This error has to connect the connector (red, green, white, black, black) in the wrong place in panel. yc1 - yc9
SOURCE: how do I clear error code c5300 in kyocera 4050
hard reset, check out link
https://community.spiceworks.com/how_to/1470-kyocera-km-xx50-hard-reset-procedure
press helpful button
SOURCE: HOW DO I FIX ERROR C6400 ON MY KYOCERA KM-4050 PHOTOCOPIER
check all conectors wiring , the engine board that cause to 6400, check also power supply maybe loose conection or some croded portion inthe board
