The computer was installing mb drivers and was installing intel optane memory and said it needs to restart so it restart and power off and i tried turning it back on but nothing happens. it has power cause i see lights on the internet jack and my external dvd driver turns on i can open it and when i power it up i can hear my computer case turn on but nothing happens
Best to remove all ram and any hardware changes, replace original ram,also delete new opane drivers speakers and all peripherals. Also remove battery tap power button for 5 seconds.
reboot to bios and enter, select setup defaults. now you should continue to original splash screen.this may seem odd, but I have seen a mouse dongle left in and caused a trouble during troubleshooting. this is why as an I.T.TECH, I recommend removing everything, such as speakers,headphones,ext hdd
Otherwise check utube search .for intel optane
SOURCE: power problems
Hi Gohan102, Open the battery compartment, and remove the battery. Look at the bottom inside corner for a little square sticker with has marks on it. is it dark or light, If it is dark, your PSP has come in contact with moisture. I suspect that your PSP has gotten wet or damp. If the sticker is dark, you need to keep your battery out for about 2 days, and keep the UMD door open and the whole PSP kept in a dry environment. Try it after 2 days of drying to see if it is recovered. Good luck Gohan....
SOURCE: Speakers don't turn back on after removing the heaphones
The way you described convinced me that your audio driver is OK, but the sound can be heard through the headphone only. If this is the case then you have a mechanical failure (metal fatigue) on the head phone jack assembly.
I consists of two DPDT switches ganged together in a small housing with have 3mm jack on it. The leaf spring contacts failed to make after the headphone plug is detached. Only skilled technician can remove it from the PCB then sold an new one in.
SOURCE: driver problems
Try installing service pack 3. I have found from experience that drivers that were not found with sp2 installed were suddenly located after install of sp3.
SOURCE: Dell Dimension 8400 won't turn-on/respond after having problems
i recommend u to install windows7 ultimate
it will automatically install drivers and solve driver related issues.
