Do you mean a charger plugged in for four months ? or the battery pack on the scooter for four months ? if it not charging and left on the scooter they will discharge and may never recover.
Leaving it on charge for four months ?, the charger will go into trickle charge mode once it fully charged the batteries, manufacturers will agree this is a good thing , if left for weeks and weeks , it should be charged up fully once a week if not in use and i recommend removing the battery case as i seen issues arise from leaving a battery pack on a scooter for long periods of time, for starters they discharge quicker,.
SOURCE: where and how do I replace my battery for my pride
Do not use batteries with different amp-hour (Ah) capacities. Do not mix old and new batteries. Always replace both batteries at the same time.
MANDATORY! Battery posts, terminals, and related accessories contain lead and lead compounds. Wear goggles and gloves when handling batteries and wash hands after handling.
WARNING! Always use two batteries of the exact same type, chemistry, and amp-hour (Ah) capacity. Use 12 Volt deep cycle batteries.
1.Remove the battery pack from the Travel Scooter.
2.Carefully turn the pack upside down.
3.Remove the eight (8) screws from the perimeter of the battery pack.
4.Carefully turn the pack right side up and remove the lid.
5.Disconnect the black (-) and red (+) battery cables from the battery terminals.
6.Remove the old battery.
7.Place a new battery in the battery pack.
8.Connect the red battery cable to the positive (+) battery terminal.
9.Connect the black battery cable to the negative (-) battery terminal.
10.Position the lid back onto the battery pack ensuring all wires are inside the pack so they don’t become pinched.
11.Carefully turn the pack upside down.
12.Reinstall all screws and tighten.
13.Charge the new batteries for 8-14 hrs before the first use.
I hope this helps and good luck!
SOURCE: I have a gogo three wheeler and some times when i
The go go controller has a controller which will give you a specific beep code to indicate the problem with your scooter. From what you are describing, it seems that the throttle potentiometer is out of neutral at start-up. The controller needs to electrically sense the throttle pot is in neutral (center of left and right) to start. By turning the scooter on and off you are jiggling the pot enough to get it to zero out(go to neutral).
Please get back to me with the exact model of the go go and with the exact number of beeps in the error code and I will be able to diagnose the problem in a more definitive way.
The most common error codes involve the throttle pot out of neutral at start-up and the brake freewheel lever is in freewheel.
You can see if the throttle pot is out of neutral by moving it slightly in either direction with one hand and turning the scooter off and on with the other hand. If the scooter works by this slight adjustment of the pot, then this part needs to be replaced. Hope this helps.
SOURCE: wiring for pride ultra x GoGo .... under the
usually there are tons of wires which are put in these units for diverse purposes. As you stated it could be for the diagnostic computer. Although it could also be for another purpose but most likely one or more sensors on the unit. Usually i would say if the unit does not undergo any malfunction then it is best left alone. What other symptoms does the unit show which you think is caused by the wire?
SOURCE: I have a pride gogo
Regards,
Tony
SOURCE: battery stuck in pride gogo mobility scooter how to remove
Hello Bruce,if you contact a local dealer for your scooter.Ask them to download you an owners manual,there will more than likely be a small fee for this.Alternatively visit the Products website & ask the same question,this may be a better option as there may be no fee.They could send you 1 in the post.I hope this has helped you,Colin.
