SOURCE: embroidery stick
You need the USB Manager software to view the files. Have a look at all the software that were supplied with the machine. Load the embroidery software on your laptop and then open the USB manager.
When it opens it will show a light blue screen and grey icons to the left. Click in "disk", then click on "read disk" and you should be able to see your designs. The grey icons will turn orange were designs are stored, and the grey ones indicate empty space for more designs.
Enjoy your fantastic machine
SOURCE: USB embroidery stick erases
If you got this machine from a sewing machine dealer, shame on them for not describing how to handle this issue.
When you open your Disk Manager USB application to add designs, first read the stick. This will take all of the designs into Disk Manager. Now you may select where you want the new designs to be added and you can delete old ones that you don't want on the stick any longer. Now, write to the stick. Yes, all designs will be erased, but read them first so they will be written back onto the stick.
If you are into computers you may understand fragmentation of the hard drive and the need to occasionally defrag. By erasing the stick and rewriting it each time, we avoid fragmentation and maximize the storage space on the stick.
By the way, if you purchased your machine on-line or through a private party you should check with your local dealers and see if one of them may have an adoption service. Some dealers frown on private sales of machines, but some of us see it as an opportunity to get a new person interested in what we do. There will usually be some type of fee for receiving the same services that a dealer offers to customers who purchase in their store. It never hurts to check around.
SOURCE: need help with transferring designs to machine
Put the cd into your computer drive and open it. Put your usb stick into one of the ports and open it as well. You must have the emb folder on the usb stick to put the designs into. If they are not there already- turn off your sewing machine and put the stick in. Turn on the machine and go to settings, then embroidery. Find the one that says Format. and touch that one and then let it do it's thing.
Once you have the folders on the usb stick- you can highlight the design name you want from the list (cd file) and drag it to the folder on the usb stick. Alternatively... right click on the design you want to move. Select copy. Open the folder on the usb stick and right click inside it. Select Paste. The design should appear in the folder for the usb and then you can take it out of your computer... put it into the machine and find the design.
If I can help with anything else... lmk.
Tracy in Nashville, TN
SOURCE: Husqvarna Viking Designer I breaking needles
Dls8864's suggestion was a very good suggestion - make sure the metal stitch plate is pushed all the way to the back. Also make sure that the thread is feeding freely - if it is catching on something it can cause the needle to be pulled aside and make it break. Does the design fit properly inside the hoop you are using? If the foot and/or needle strike against the side of the hoop, that will cause a breakage. Is the bobbin thread okay - not making a bird's nest underneath?
SOURCE: The 3-D embroidery system seems
USB Designer 1s use Disk Manager, just like their floppy disk sisters, but it needs to be Disk Manager USB. New USB Des1s came with this program on a CD, and this software was also included free when a floppy disk Des1 was converted to USB. If you bought your D1 USB new, check the disks that came with it - one should be Disk Manager USB. If you purchased the machine second hand, contact the seller and ask for the program. It is a free standing program and you don't need a dongle. Check your 3D software - you might already have what you need. Open 3D, click down arrow for Accessories (far right-hand side) - what does your Disk Manager say? If it says Disk Manager USB you are okay to go.
I am not 100% sure of this, but I think that maybe the last update for 3D software (version 7.25) might have included Disk Manager USB. Go to the Husqvarna website and make sure your 3D is updated to the latest version.
If none of the above helps you, there is always the cheap cost embroidery software alternatives: Embird or Sew What. I believe they can write to Designer 1 USB sticks now.
Testimonial: "For some reason I thought that the 3D software was up to date for USB, but it wasn't. Thank you, thank you, thank you. You are a lifesaver!!!! "
