Sony Playstation 3 (PS3) Console Logo
Posted on Aug 04, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My ps3 has just started to stop playing blu ray films after 20min
My ps3 has just started to stop playing blu ray films they play the first 20 mins then freeze but my ps3 games still all work fine
Ben Wabnick
Level 3:
  • Sony Master 2,404 Answers
  • Posted on Aug 04, 2009
Ben Wabnick
Sony Master
Level 3:
Answers
2404
Questions
Helped
883875
Points
7655
The laser is starting to go bad in the dvd drive. It takes more power for the drives laser to read and play a blu ray movie then it does to play a dvd game.
You can either replace the laser if you have the technical knowledge to take the dvd drive apart, or just replace the drive. You can usually find either one on ebay.
3helpful
2answers
Honedownloaded amovie to watch on my ps3 put it on my portable hard drive from my laptop to watch on the playstation 3 the film gets 3 mins in then comes up with chavia message code 1
Cinavia is an anti-piracy protection embedded into the PS3 and it triggered by some codes in the audio track of the movie.
You cant play Cinavia protected movies on the Playstation 3 native player.
However If your Ps3 is jail-broken you can use a homebrew player to play those movies.
3answers
My ps3 will play ps3 games but not dvds. it loads the dvd then turns black. Any suggestions?
You can follow below steps to play DVDs on PS3.
Step 1: Insert Blu-ray disc into PS3's Blu-ray drive. Playing Blu-ray disc movie works exactly the same way as entering a game, except you need to head into the Video Tab in your PS3's home menu, rather than the Game Tab. Highlight the Blu-Ray and press X to start it immediately.
Step 2: Now the Blu-ray disc will load like a traditional DVD. Use your controller to access the menu, and use the D-Pad to select your option and press X to enter. When the media is playing, you can press triangle to open a mini-menu that will give you access to options such as subtitles, audio channels and volume. You can also access the main menu, using the arrow keys to navigate. Press triangle again to close this menu.
However, if you can't do it successfully, try to convert DVD to regular video and transfer to PS3.
Step 1: Download and install Leawo Blu-ray to PS3 Converter, and then launch it.
Step 2: Get source Blu-ray movies ready. Insert Blu-ray disc to the Blu-ray drive, or get source Blu-ray folders ready for loading and converting.
Step 3: Load Blu-ray sources
Click "Add Blu-ray/DVD" button on the program interface. This Blu-ray to PS3 converter would then guide you to browse source Blu-ray movies for loading.
Note: After loading source Blu-ray movies, you could select subtitles and audio tracks, play source Blu-ray movies, edit Blu-ray movies, snap screenshots, etc.
Step 4: Do output settings
Next to the "Add Blu-ray/DVD" button, click the dropdown box and select "Change". You will then arrive at the Profile setting panel to select output format from "Format" group or "Device" group. Select "MP4? from "Format" or directly choose "PS3? from "Device > Sony".
Optional settings: After you've set the output format, click the same dorp-down box and click "Edit" option and then you could adjust video and audio parameters of selected profile, including: video codec, audio codec, bit rate, aspect ratio, frame rate, channel, etc.
Step 5: Start converting Blu-ray to PS3
Back to the main program interface, click the green "Convert" button. You could then set an output directory on the right popup sidebar. After setting output dirctory, click the below convert button to let this Blu-ray to PS3 Ripper instantly start converting Blu-ray to PS3 videos.
Note: Internet connection is required during the whole conversion.
After you convert Blu-ray to PS3 friendlier videos, you can transfer the videos to PS3 and then start to play Blu-ray on PS3 in a indirect way. For details, you can read the extension part.
For more details, check: Direct and Indirect Ways to Play Blu-Ray on PS3
2answers
Doesnt like playing films
Your PS3 is not correctly loading his firmware, if its new, bring him back and say what happened.
It plays blu ray for about 10 mins
in this case if your out of warranty open your console and clean the laser with iso alchohol and a q-tip re assemble and see what it does if it still has the prob call a company called innex and order a new laser
work case sin is a daughter board replacement hope this helped rate high if so
3answers
Ps3 wont play movies
My PS3 met the same issue. But I have tried to convert the Blu-ray to HD video and transferred to PS3 for playback. Maybe you can do this like me.
Leawo Blu-ray Ripper is an easy-to-use Blu-ray to PS3 converting tool to help you rip and convert Blu-ray file to PS3 videos in only a few simple clicks. The below step-by-step guide would tell you the details on how to rip and convert Blu-ray to PS3 videos with Leawo Blu-ray to PS3 Converter.
Guide on how to convert Blu-ray to PS3 videos:
After the conversion is completed, now we should transer Blu-ray movie now in PS3 fridlier video format to PS3 for playing Blu-ray on PS3. Follow the steps below to do so.
Here is a simple step-by-step guide for transferring to or watching video files on your PS3 using a USB flash drive or an external hard drive.
Step 1: Plug a USB flash drive or an external hard drive into your computer and copy over the converted video files that you want to watch on your PS3.
Step 2: After the copying process is done, pull out the USB flash drive or the external hard drive from your computer and then plug it into one of the USB ports on the PS3.
Step 3: Navigate to "Video" on the PS3 XMB menu and find your device, hit triangle to view all contents and select the file you want and either copy it to the PS3 hard drive or just play it directly from the connected device.
By following the guidance above, you can achieve your goal of more safely and conveniently playing Blu-ray on PS3 or watching Blu-ray on PS3 for protecting either PS3 Blu-ray drive or your precious Blu-ray discs from being scratched.
Ps3 not reading discs!
what is wrong is when you got the blue ray set up it was probly set up diff.if it is not reading games or movies then you eye is scrached.the eye if u dont know is what reads everything
Ps3 will not play discs
You will need the laser replaced.
5helpful
2answers
Acoustic Solutions 26'' HD TV cannot play PS3 blue ray films
I have recently brought the same TV and had the same problem but I've mangaed to find a soultion.
The automatic setting for Blu Ray on PS3 is Full HD (1080p) but the Acoustic Solutions TV is HD ready (720p). For PS3 games it will automattically change settings for you to 720p. This is why this works straight away but Blu Ray doesn't.
Solution
You need to plug in your PS3 using the scart contection, then on the ps3 menu go to settings > display settings > HDMI. You will then need to attach the HDMI cable and manually set up
HDMI by checking the 720p option and deselect 1080p.
That should then play Blu Rays too. You don't lose too much quality as 720p works nearly as well as 1080p on smaller TVs.
Rich
Help
power is shorting-out....or cpu "overheating"
Top Sony Video Game Consoles & Games Experts
Grand Canyon Tech
Grand Canyon Tech
Jose Ramirez
Alexander
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
