GE oven
Hello, Deborah -
I hope I am correct in thinking that you do not have the owner's manual for your oven. If you do have the manual, failure codes are probably listed in the manual, with an explanation of what they mean.
According to information on the list of GE Wall Oven Error Codes provided by Sears PartsDirect:
https://www.searspartsdirect.com/wall-oven-repair/error-codes/ge-wall-oven-error-codes.html
F1 means:
Stuck or defective button on the key panel
The check / repair is:
(Quote)
Push the Clear/OFF pad. Shut off power to the oven, disconnect the flat ribbon connector from the electronic oven control board and then restore electrical power. If the code reappears after about 30 seconds, replace the electronic oven control board. If the code doesn't reappear, replace the key panel.
(End quote)
Best wishes.
SOURCE: GE True Temp Oven Timer Instructions
go to this web site put in your model number and you can download the whole use and care manual http://www.geappliances.com/ just look for the search box half way down on left select use and care then put in the model number
SOURCE: GE Profile -Installed wall oven - won't heat
brand new??? under a year old??? if so you have a warr call for service, but it sounds like an ignitor isssue, brand new , perhapsgot damaged in shipping 1-800-ge-cares
SOURCE: GE True Temp oven won't turn off.
The sensor is a part number WB23T10002 and goes for about $60. The paper inside the control area of the oven will state the normal resistance values of it. (probably about 1080 ohms at room temp, about 2650 at clean temp.) If you cut a lead to it, you would just get a F3 code, and if you cut the other and wire them together, just get a F4 code, so that wouldn't help diagnose the problem, but if you could use an ohm meter on the probe it would. BUT the oven should not come on without it being set to bake, SO I conclude that the ERC is indeed the problem (with the welded electrical contacts), which is a part number WB50T10043 which might go for about $125 or so. If you are careful when you replace it, you can probably peal the faceplate (part # WB27T10125) off and reuse it, so you should just need the ERC.
SOURCE: my GE true temp has the error code F7 EC. I cannot
Please, don't replace anything, stop letting people rip you off, try this! The insulation in the ribbon cable is poor. The conductors in the cable are crossed. The ribbon cable is actually two ribbons pressed together, and the conductors between the two cables are shorting or becomming crossed. Lift the two cables apart, place a piece of paper between them, fold the edges of the paper over the cable so that it does not slip out, and make sure to shove it all the way down to where it will meet the plastic display panel housing. There, problem solved.
