SOURCE: error codes for indesit front load washing machines
The F002 error codes relates to a motor problem. Do you know if the motor spins ?
SOURCE: Indesit front loading washing machine error code
i am a recently retired engineer of 20 years, but this sounds like (based on the info given) a heater element fault, after the machine fills up and agitates a few times the heater should start, check the heater for open circuit, replace if needed, of course it just could be a wire off? if i have helped rate me please
SOURCE: LG front loaded washing machine vibrates during
If its on a pedistal then that will raise your center of gravity and cause the unit to be less sturdy during a spin. It could also be due to a weak floor. You may want to try a product called "shake away pads". The probably sell them at like home depot or lowes. They will run you about 40 bucks but they just go under the legs and help absorb some shock. Good luck _MJ_
SOURCE: there is a cockrach in the idicator of my IFB
ewww! If I had cockroaches I would MOVE! Gross!
SOURCE: my ifb washing machine digital
You will need to type into your search engine the '(make) washer manual' and you should be presented with a number of sources from which you can either download for free or have to pay a nominal amount. During the process you will be asked for the actual model number!
Good luck,
John C
