Televison & Video Logo
Sweet Tooth Posted on Dec 20, 2018
A denon AVR1505 and remote
Do I need remote for sound set up... is there any way to get it manuelly
Cal Humrich
Level 1:
New Friend:
  • Contributor 28 Answers
  • Posted on Dec 26, 2018
Cal Humrich
Contributor
Level 1:
New Friend:
Answers
28
Questions
0
Helped
14164
Points
61
If you have the Audyssey set up mic, plug it in and follow the on screen instructions. Or try installing the Denon AVR remote app.
Using a Denon Rc1068 remote how do I change inputs on my Denon AVR?
The Denon RC-1068 universal remote has an Amp button on the top left side of the unit. This button toggles through Amp, Zone 2, Zone 3, Zone 4 (on some devices) and System Call. In the Amp mode, it will control your Denon device default zone. If the remote is set to one of the other zones/modes, press the Home button (right side in the row with the Quick Select keys, above the surround sound buttons) to return to the Amp mode. Then press the Input button (on the left side), below the tuner buttons, to select the audio-visual source that you want.
See the manual for the remote at ManualsLib, https://www.manualslib.com/manual/886505/Denon-Rc-1068.html#product-RC-1068 . The picture of the remote buttons is here: https://www.manualslib.com/manual/886505/Denon-Rc-1068.html?page=2#manual .
I hope this helps.
I need a remote for my Denon surround sound AVR-1803/883
You can buy any Denon av-amp remote to control your av-amp.
Can i use my denon rc-828 on my denon dvd2900
If the remote control have set-up codes to your denon dvd, you can.
If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common codes to check devices with different brand TVs are given, in the order of the device's brand name list in alphabetical order. Pull up older posts. Surf the site with patience.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
2answers
I have a Denon AVR 790 for about 8 months now. Hooked up a combo DVD VCR player using the red/yello/white cables. It worked fine for about 6 months. Now I cannot get the DVD or VCR to play. I get sound,...
If dvd combo player is only video source connected with Denon AVR 790 then unplug yellow video wire from Denon and plug it directly in TV input, now video signal will go directly to tv and sound will come from Denon AVR 790 speakers during dvd playback.
This is simple bypass that wont effect surround sound of dvd playback.
Let me know if you have additional question.
Thanks.
Replacement Remote for Denon DC-1
There are a number of Denon remotes listed here:
Denon Remotes
You will have to ask via email if one of these will work with your system-
Denon avr-1907 sound from TV stopped working
Help with hooking PS3 to a Denon Receiver. It worked before, but I had to move everything to a different location and when I hooked it back up the PS3 has sound but no picture. I have it hooked directly to the receiver with and HDMI cable (the receiver is hooked up to our cable box which is directly hooked to the tv via HDMI cable).
I need to set multi coponets
Your best set up is to plug the DVD and the direct tv optical or coaxial out. The Denon has both. You will then have to choose digital input on the receiver. There is a blue indicator light that will light and a graphic that will show all speakers are working. There is also a pink noise test that will play each speaker in order. This test button is located on the remote.
Picutre but no sound
audio will not run through an s-video cable.   it is only for video.  you will have to still connect normal cables (red/white) to get sound.
Top Denon Televison & Video Experts
 Grubhead
Grubhead
ADMIN Andrew
ADMIN Andrew
Are you a Denon Televison and Video Expert? Answer questions, earn points and help others
