Computers & Internet Logo
P
Pete Laughlin Posted on Dec 19, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Changed out atx power supply because computer not powering up. Do I replace with same motherboard with same or buy new Windows 10 Box.
Gigabyte GA-F2A D3H and AMD A series processor Windows 8 upgraded to 10 last year.
Larry Ng
Level 3:
Top Expert:
  • Gigabyte Master 14,591 Answers
  • Posted on Jun 04, 2022
Larry Ng
Gigabyte Master
Level 3:
Top Expert:
Answers
14591
Questions
0
Helped
3278056
Points
66570
Ok, a simple hardware question only. w10 could careless about PSU. (facts) mobo is micro atx size 24.4cm x 24.4cm
not powering up has many causes, even simply stuck in sleep mode. (power on button held for 10seonds and released last is 1 cure. of about 20 causes (up to)
GA-F2A78M-D3H (rev. 3.0)or rev. 4.0????? rev is on bottom left of mobo, normal tower case. no case told
the PSU is called ATX and all work here 500 to 750watts
24 pin power is normal
but CPU power uses 8 pin power plug PSU.marked ATX12v
psu lacking 8 pin, can use 4 to 8 adpater.
vast here work, in real ATX case not micro cases.
https://www.newegg.com/p/pl?d=psu+atx&N=4131%20100007657%20600014006%20600479294&isdeptsrh=1&Order=1
from you manual .
Changed out atx power supply because computer not  - 12vatx-undefined-undefined-0.jpg dead PC
are all fans dead.> that is dead PC.
the monitor must be good and connected the the VGA jack
if using GPU card then it must connect to the monitor
the BIOS screen must work or the PC is dead or GPU card is dead.
strip the PC down ,any thing in the PC shorted will make PC dead.
if strip down tests fail the PSU may be bad is its fan dead too?
both power connectors most be connected above or PC will be dead.
5 Related Answers
sparky1500
Matthew Spark
  • 1066 Answers
  • Posted on Jul 01, 2009
SOURCE: won't boot
power supply isnt putting out enuf power
anaesarora
Arora Singh
  • 180 Answers
  • Posted on Sep 19, 2009
SOURCE: my AMD x4 processor problem with gigabyte motheraboard
please load windows xp 64 bit . it will work well.
also check the temperature of motherboard and processor in bios
if temperature high use good heat sink and cpu fan .
Anonymous
  • 3 Answers
  • Posted on Oct 18, 2009
SOURCE: PROCESSOR, MOTHERBOARD AND POWER
Some motherboards with 8-pin and 24-pin power connectors support 4-pin and 20- pin connectors, like my Gigabyte GA-MA790GPT-UD3H AM3 AMD 790GX.
joecoolvette
joecoolvette
  • 5660 Answers
  • Posted on Apr 16, 2011
SOURCE: My motherboard takes this: 1 x 8-pin ATX 12V power
Better than Amazon.com Andrew,
http://www.directron.com/ad202.html
Converts two 4-pin standard Peripheral power cables, (Molex) to one female 8-pin EPS +12 Volt power cable.
4-pin Peripheral +12 Volt power cable,
http://www.playtool.com/pages/psuconnectors/connectors.html#peripheral
[ NOTE*
Designated a 4-pin Standard Peripheral power cable, because there is a 4-pin Small peripheral power cable ]
A) 8-pin EPS +12 Volt power cable,
http://www.playtool.com/pages/psuconnectors/connectors.html#eps8
B) Note the difference from an 8-pin PCI Express power cable,
http://www.playtool.com/pages/psuconnectors/connectors.html#pciexpress8
{4-pin Small peripheral power cable,
http://www.playtool.com/pages/psuconnectors/connectors.html#floppy
Used on the older Floppy Drives, and also used on today's Card Readers in desktop computers }
Testimonial: "awesome"
Anonymous
  • 39 Answers
  • Posted on Sep 05, 2012
SOURCE: I have a Acer AX1200-U1510A AM2+ Motherboard and i would like to upgrade the processor, ihave 4 gigs of mem and a 1 gig Gigabyte Gt 610 graphics card. I only have a 240 watt power supply what processo
Should work with a processor of the same socket type. I'd seriously upgrade the psu myself. Personally I'd upgrade the motherboard and processor to a quad core, and get the fastest ram, look at ebuyer.com, you can buy a bundle upgrade package for less than you may think. :)
1helpful
4 pin power addapter on motherboard
Just buy a new ATX-12V power supply. They are cheap enough.
How to physically replace the power supply connector that is soldered to the motherboardon the right side of the memory modules
itis possible but you need to solder it on again without making a conection with other component so rather take it to the pro
New GA-990AX-UD3 motherboard will not boot
You really should take that Power Supply, and use it on grandma's computer.
The 8-pin EPS +12 Volt power cable was brought out, to provide more power To the motherboard AND processor.
The 4-pin ATX +12 Volt power cable has TWO yellow wires.
Yellow wires are 12 Volt wires. (And two Black ground wires)
http://www.playtool.com/pages/psuconnectors/connectors.html#atx12v4
The 8-pin EPS +12 Volt power cable has FOUR 12 Volt wires.
In the motherboard manual, does it say, "Yes Tom. Go ahead and use a 4-pin ATX +12 Volt power cable. We don't care. We just use an 8-pin EPS for fun."
[ This is an 8-pin PCI Express power cable. Completely different,
http://www.playtool.com/pages/psuconnectors/connectors.html#pciexpress8 ]
The motherboard probably uses 150 Watts by itself.
No Ram Memory, no CPU, no fans, etc.
The CPU could use up to 125 Watts of power. Just depends on what AMD, socket AM3, processor you are using.
Now to graphics card's power;
The most Wattage a PCI-Express x16 slot can deliver is 75 Watts.
The most power a 6-pin PCI Express power cable can deliver is 75 Watts.
8-pin EPS +12 Volt power cable? 150 Watts.
When buying a Power Supply you should calculate all components needing power,
http://extreme.outervision.com/psucalculatorlite.jsp
,then buy a Power Supply that has AT LEAST 10 percent more power than needed. Easier on the Power Supply.
Also a computer will NOT use more power than it needs.
10,000 Watt power supply, (Exaggeration ), and the computer only needs about 100 Watts for surfing the internet?
Computer ONLY uses 100 Watts.
Due to the price, the above, and the availability, you should use a 500 Watt power supply at least.
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=899123&CatId=1079
http://www.amazon.com/StarTech-6in-Pin-Power-Adapter/dp/B002O21XHQ
Or use it on yours if it has enough Wattage.
Back in the day, the motherboard didn't need to supply that much power to components on it.
More powerful Processors, Ram Memory, and graphics cards, brought the power needed, up.
A 4-pin ATX +12 Volt power cable was added for the motherboard. Then 6-pin PCI Express power cable for graphics cards. Then the 8-pin PCI Express power cable for graphics cards. Lastly the 8-pin EPS +12 Volt power cable.
(Better make sure the Power Supply you have is good, if you wish to use the above power adapter cable. Nothing like having a Power Supply with a weak voltage power rail, and a new build, to pull your hair out on )
http://www.gigabyte.com/products/product-page.aspx?pid=3894#ov
Out of the motherboard manual Page 23,
"With the use of the power connector, the power supply can supply enough stable power to all the components on the motherboard. Before connecting the power connector, first make sure the power supply is turned off and all devices are properly installed. The power connector possesses a foolproof design.
Connect the power supply cable to the power connector in the correct orientation. The 12V power connector mainly supplies power to the CPU. If the 12V power connector is not connected, the computer will not start.
To meet expansion requirements, it is recommended that a power supply that can withstand high power consumption be used (500W or greater). If a power supply is used that does not provide the required power, the result can lead to an unstable or unbootable system."
For additional questions please post in a Comment.
Regards,
joecoolvette
2answers
Gren orange and red lights on motherboard when I turn on computer then it powers down automatically
Hello khems71, hi your PC problem is caused by a faulty power supply box, or worst you motherboard, buy try first to replace your Power Supply box, DOUBLE Check also your connections on your motherboard.
Power supply FOR ASUS P5GC-MX/1333
Dear,
Yes you can use that power supply for both one.
Cheers
Jaggu
1helpful
I have a Motherboard gigabyte GA-8PE800. when i
The ATX 12v ( 4 pin Connector ) is For The CPU Power.
This could Indicate, either A Faulty CPU.
Or a fault To The Motherboards ( BGA ) or CPU Socket Holder.
Or alternatively, The Actual PSU Itself is Faulty.
You can obtain A CPU Socket Tester from e-bay. And A PSU Tester.
Hope This Helps Mike @ Compurepair.
Gigabyte motherboard ep45-ud3p shutdowns after bootup
Good day sir/maam, the reasons are several, but there are two common reason why it behaves like that.
  1. Bad windows installation or it is infected by a virus that resets you pc regularly, you may need to reinstall a clean copy of windows and scan all your flash drives with anti-virus softwares.
  2. Bad power supply box. swap out any good power supply or better buy a new one.
hope this helps, feel free to ask hope this helps.
1helpful
Compaq 120694-101 Motherboard would like to totally upgrade
Your PC case will hold any atx motherboard with 4 or less expansion slots. Just about everything made now will fit. You will have to replace your power supply if it still has the standard factory unit installed. The newer boards require an ATX power supply with the additional 4 pin plug for extra power to the CPU. Go to newegg and look for combo deals, they run them all the time. Here is a gigabyte board that is very nice. GIGABYTE GA-MA78GM-US2H Micro ATX AMD Motherboard image-3300643-10440897
I hope this solution helps you out.
Buddy
Corporate Computer
Over 21 years of PC and printer support/repair
2answers
No power
reg desktop computer ? 4 screw on back unplug it out buy new one atx style for latest computer sum use mini small power to fit in smaller cases micro atx let me know more info
Top Gigabyte Computers & Internet Experts
MegaByteMe
MegaByteMe
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
